Buffalo 2TB MiniStation Thunderbolt + USB 3.0 2.5" Portable HDD
Quicklinx: 9NJBWS00 Mfr#: HD-PA2.0TU3-EU
Buffalo Technology's MiniStation Thunderbolt Portable HDD is portable Thunderbolt with an USB 3.0 dual interface external drive solution. The Thunderbolt (10 GBps) interface is twice as fast than USB 3.0 while preserving backward compatibility with existing devices that support USB 2.0 or USB 3.0.
Bus-powered, the MiniStation Thunderbolt Portable HDD requires no additional power supply and is easy to carry. Just plug the portable HDD body with the included Thunderbolt Cable onto your Mac. Enclosed in a sleek aluminum body with a transparent frosted top, the design feels luxurious. MiniStation Thunderbolt Portable HDD features an indirect disk access LED indicator on the underside that tastefully illuminates its supporting surface.
With the MiniStation Thunderbolt Portable HDD on the move, you can transfer digital content faster, simplify connections between devices, maintain compatibility with most devices and enjoy the ultra-fast speeds of the market's latest portable storage solution.
  • Ultimate speed
    Thunderbolt (10 Gbps) interface. Two times faster Interface speed than USB 3.0.
  • Dual-interface
    Thunderbolt and USB 3.0 for the best possible speeds.
  • Bus powered
    No additional power input required.
  • Design
    Sophisticated design.
BUFFALO MiniStation Thunderbolt - hard drive - 2 TB - USB 3.0 / Thunderbolt
Hard drive - external (portable)
2 TB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Apple Time Machine compatible, HFS+ formatted
Power Source
USB bus, Thunderbolt bus
80.5 mm x 130 mm x 22.5 mm
260 g
2 TB
Internal Drive Interface
Serial ATA
80.5 mm
130 mm
22.5 mm
260 g
Performance
Interface Transfer Rate
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B , 1 x Thunderbolt - Mini DisplayPort
Power Source
Microsoft Windows XP, Apple MacOS X 10.5 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
1 x USB 3.0 cable - external , 1 x Thunderbolt cable - external
5 °C
35 °C
20 - 80% (non-condensing)
