Buffalo Technology's MiniStation Slim portable hard drive brings you the Buffalo quality you know and trust in a remarkably small and attractive aluminum package. And, in addition to its good looks, users will be impressed with the MiniStation Slim's high speed data transfer via USB3.0.
- BUFFALO MiniStation Slim - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Bus Powered by USB, Apple Time Machine compatible
- Power Source
- USB bus
- Enclosure Colour
- Silver
- 79 mm x 115 mm x 8.8 mm
- 140 g
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- 79 mm
- 115 mm
- 8.8 mm
- 140 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- Buffalo Tools
- OS Required
- Apple MacOS X 10.8 or later, Microsoft Windows RT / RT 8.1, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- Enclosure Material
- Aluminium
- Enclosure Colour
- Silver
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
