Buffalo 2TB JustStore Desktop Storage Hi-Speed USB2
Quicklinx: 72TVWS00 Mfr#: HD-E2.0TU2-UK
Store, back-up, or easily transport all file types including huge multimedia files too large to fit on a USB key, with the Buffalo JustStore Desktop. An innovative, fan-less design and power-saving mode make this Buffalo JustStore Desktop a dependable, economical and silent USB attached storage solution. With auto installation, easy operation and auto power on/off, you can quickly store, access, and transfer files, digital images, documents, and backups. Just plug it in to a PC or Mac and it works!
BUFFALO JustStore Desktop - hard drive - 2 TB - USB 2.0
Hard drive - external (desktop)
2 TB
USB 2.0
Data Transfer Rate
480 Mbps
Power Source
Included AC adapter
4.5 cm x 15.6 cm x 17.5 cm
1 kg
United Kingdom
2 TB
USB 2.0
Internal Drive Interface
Serial ATA
4.5 cm
15.6 cm
17.5 cm
1 kg
Performance
Interface Transfer Rate
480 Mbps
Expansion & Connectivity
1 x USB 2.0 - 4 pin USB Type B
Power Source
Included AC adapter
Power supply
Power Consumption
12 Watt (active)
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.2.7 or later, Microsoft Windows Vista
Plug and Play
United Kingdom
Limited warranty - parts and labour - 2 years
5 °C
35 °C
20 - 80%
