Buffalo's DriveStation USB 2.0 Hard Drive HD-LBU2 is an easy to use external hard drive to add additional external storage to any device using a USB port. The DriveStation features a sleek, black glossy chassis that can be positioned vertically or horizontally, adapting to the location it is used in for an efficient use of space.
Get more storage instantly by simply plugging in Buffalo's DriveStation™ USB 2.0 Hard Drive HD-LBU2 to a PC or Mac via a USB port. The Buffalo DriveStation™ is a quiet external hard drive in a black glossy chassis that looks stylishly sleek whether you place it upright or flat. Its adaptive design allows efficient use of space.
Auto functions
The DriveStation™'s auto installation and auto power on/off features make it easy to use, and provide an economical solution where you can quickly store, access, and transfer files, digital images, documents, and backups.
- Compatible Interfaces: USB 2.0 Interface - connects to USB on any PC or Mac
- Pre-formatted drive: Ready to use, anytime
- Connect and go: Easy to use and setup, simply plug it into the USB and play; no drivers required
- USB Interface: Standard Compliance USB 2.0, Connector Type USB Type B, Number of Ports1, Data Tansfer Rates Max. 480Mbps (USB 2.0 Mode)
- Dimensions (WxHxD) 38.7 x 122.6 x 189mm
- Weight 950g
- OS SupportWindows®7 (32bit, 64bit), Windows® Vista™(32bit, 64bit), Windows® XP, Mac OS 10.4 or later
- BUFFALO DriveStation - hard drive - 2 TB - USB 2.0
- Hard drive - external (desktop)
- Capacity
- 2 TB
- Interface
- USB 2.0
- Power Source
- Included AC adapter
- Enclosure Colour
- Glossy black
- 3.9 cm x 18.9 cm x 12.3 cm
- 0.95 kg
- Localisation
- United Kingdom
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 2.0
- Internal Drive Interface
- Serial ATA
- 3.9 cm
- 18.9 cm
- 12.3 cm
- 0.95 kg
Performance
- Max Data Transfer Rate
- 480 MB/s
Expansion & Connectivity
- 1 x USB 2.0 - mini-USB Type B
- Power Source
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Power Consumption
- 12 Watt (active)
- OS Required
- Microsoft Windows XP, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
- Enclosure Colour
- Glossy black
- Localisation
- United Kingdom
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
