Attractive, Nimble, and Ready-To-Go
Buffalo Technology's new MiniStation™ Portable Hard Drive series are sleek and lightweight portable USB Storage devices, utilising cutting edge USB 3.0 technology in a new, slim form factor.
The new MiniStation™ brings you the Buffalo quality you know and trust in a small, attractive, and affordable package. In addition to its good looks, users will be impressed with the new MiniStation's high speed data transfer via USB3.0. This MiniStation™ series also includes the Buffalo Tools software TurboPC EX that boosts performance and accelerates the read and write speeds of both your Windows PC and your new Buffalo MiniStation™.
Features and Benefits
- Thin and lightweight: 1TB: 14 mm and 185 g
- Boost PC performance with Buffalo Tools TurboPC EX
- Plug-n-Play ready for immediate use
- USB powered, no power supply needed
- High Speed data transfer with USB 3.0
- HDD interface SATA
- Capacity 1TB
- Interface: Standard Compliance USB 3.0
- Connector Type: Micro-B
- Number of Ports 1
- Data transfer rate 5Gb/s
- Supported OS Windows 8 (32/64bit), Windows® 7 (32/64bit), Windows® Vista™ (32/64bit), Windows® XP, Mac OS® 10.6 or later
- Dimensions (WxDxH) 76 x 115 x 14 mm (1TB)
- Weight 165 g (500GB)
- Operating environment 5-35°C, 20-80% (non-condensing)
- Power supply Bus powered
Upgrading to USB 3.0
Upgrade to USB 3.0 by using a Buffalo USB 3.0 Interface ExpressCard for desktop (IFC-PCIE2U3) or laptop (IFCEC2U3UC), or via an existing USB 3.0 port. -
USB powered
No external power supply needed! -
Sleek and slim
The MiniStation is slim and lightweight, and comes with a choice of two colors - stylish white or dignified black. -
Buffalo Tools
Enhance your PC transfer performance and back up your important digital assets with the Buffalo Tools for windows.
- BUFFALO MiniStation HD-PCFU3 - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Bus Powered by USB
- Power Source
- USB bus
- Enclosure Colour
- Black
- 76 mm x 115 mm x 14 mm
- 185 g
- Capacity
- 1 TB
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- 76 mm
- 115 mm
- 14 mm
- 185 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Software Included
- Buffalo Tools
- OS Required
- Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
- Plug and Play
- Enclosure Colour
- Black
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
