Buffalo 1TB MiniStation Extreme USB 3.0 Water & Dust Resistant Portable Hard Drive - Black
Quicklinx: BK48WS00 Mfr#: HD-PZF1.0U3B-EU
MiniStation™ Extreme - The perfect solution for those who often travel with PCs and portable HDDs
BUFFALO’s MiniStation™ Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberised elements to protect it from accidental bumps.
The ingenious arrangement of shock protection features meets the U.S. Military Standard MIL-STD-810G, METHOD 516.6, Procedure IV and has passed free-fall drop tests with drops up to 2.3 meters.
Moreover, the USB cable is integrated with the case so you will not be frustrated searching for a cable anymore!
The USB 3.0 interface moves data at rates of up to 5Gbps. This vastly reduces the time needed for data transmission, making it ideal for transferring and sharing videos, large digital photo collections, music files, and other data-intensive digital content. MiniStation Extreme is available with 1TB or 2TB capacities. Both capacities are available in black; 1TB capacity is also available in red or silver.
Highly Shock-Resistant
Buffalo™ gave the HD-PZFU3 a sleek design with an attractive matte finish and Buffalo’s patented shock-proof chassis: U.S. military-grade shock protection helps protect the hard drive from damage, passing 2.3-meter free-fall drop test.
Water and Dust-Resistant
Complies with standard IPX3:
Spraying water from angles up to 60° from the vertical shall have no harmful effect.
Complies with Standard IP5X:
Dust will not interfere with the satisfactory operation.
Want more protection?
Hardware Disk Encryption: 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorised access. This type of encryption has never been broken and governments and businesses place a great deal of faith that it never will be.
Easy Cable Management
Integrated USB3.0 cable snaps to chassis for pack-and-go-portability.
  • US military grade (MIL-SPEC) shock protection
    Shock absorbers surround the hard disk protecting it from damage and drops from up to 2 meters.
  • Flex connect USB cable
    Removable, integrated USB cable snaps to chassis for improved portability.
  • Hardware disk encryption
    Automatic 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access.
  • Compact and sleek
    Slim, lightweight chassis saves space for ultimate portability.
  • USB powered
    Perfect companion for your laptop or netbook - no external power supply needed.
  • Connect and go
    Preformatted hard drive is ready for immediate use with Windows and Mac.
  • Buffalo tools
    A feature-rich software suite of tools designed to boost PC performance.
  • Back up your files
    Bu ffalo's backup utility automatically backs up your Windows PC, protecting your data.
  • Time Machine compatibility
    Works perfectly with Time Machine to back up your Mac computer.
  • Eco manager
    Eco minded power management tool regulates power usage, conserving energy and battery consumption.
BUFFALO MiniStation Extreme - hard drive - 1 TB - USB 3.0
Hard drive - external (portable)
1 TB
Hardware Encryption
USB 3.0
Data Transfer Rate
5.0 Gbps (USB 3.0)
Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source
USB bus
Enclosure Colour
9 cm x 14.1 cm x 2.1 cm
277 g
1 TB
Hardware Encryption
USB 3.0
Internal Drive Interface
SATA 3 Gb/s
9 cm
14.1 cm
2.1 cm
277 g
Performance
Interface Transfer Rate
5.0 Gbps (USB 3.0)
Expansion & Connectivity
1 x USB 3.0 - 10 pin Micro-USB Type B
Power Source
USB bus
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Microsoft Windows RT, Windows 8.1 RT, Windows 8.1
1 x USB 3.0 cable - integrated
MIL-STD 810G 516.6, IP5X, IPX3
Enclosure Colour
5 °C
35 °C
20 - 80% (non-condensing)
