The first Network Attached Storage product in the world using 2.5" hard disks! The Auto Power on / off function enables the LinkStation to turn off automatically when you shut down the last PC or laptop with installed NAS Navigator software. So small and compact that it fits perfectly in the palm of your hand, with features such as 60% lower power consumption, fanless operation and low noise make the LinkStation Mini the ideal storage solution for anywhere in your home.
- BUFFALO LinkStation Mini - NAS server - 1 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 1 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 8.2 cm x 4 cm x 13.5 cm
- 0.5 kg ()
- Storage Controller
- RAID SATA 1.5Gb/s RAID 0, 1
- Hard Drive
- 2 x 500 GB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Vista, Microsoft Windows Server 2008
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 1 TB
- 8.2 cm
- 4 cm
- 13.5 cm
- 0.5 kg ()
- Enclosure Colour
- White
- Built-in Devices
- Print server
Storage Controller
- RAID - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1
Hard Drive
- HDD
- Capacity
- 2 x 500 GB
- Interface Type
- SATA 1.5Gb/s
- Spindle Speed
- 5400 rpm
- Data Link Protocol
- TCP/IP, AppleTalk, SMB
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, Server Message Block (SMB)
- LDAP support, Buffalo Web Access, BitTorrent Client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- RoHS
- Power Device
- External power adapter
- Voltage Required
- 17 Watt ()
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
