BT4600 Advanced Nuisance Call Blocker Quad
Quicklinx: GB1LWS00 Mfr#: 101515
Type: Cordless phone
Handsets Included: 4
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
12 In Stock
£91.66 ex VAT
£109.99 inc VAT
Express delivery Order within the next 19 hours for delivery on Thursday
BT4600 Big Button Premium Nuisance Call Blocker
with 100% call blocking and answer machine
An easy to use big button phone that blocks 100% of nuisance calls.
Featuring
  • Works with all landline providers
  • Large 1.8" screen with amber backlight
  • Easy to use big buttons
  • Hearing aid compatible with amplify button to boost volume
  • Block 100% of nuisance calls1
  • Block up to 1000 numbers
  • Record up to 60 minutes of messages
  • Save up to 200 contacts
  • Do Not Disturb mode switches ringer off
  • Handsfree speaker
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Struggling to read the screen or hear callers?
This is the ideal phone for anyone with sight, hearing or dexterity challenges. The big buttons and large screen will ease the frustration of entering numbers incorrectly or misreading messages. It’s hearing aid compatible and you can even boost the volume of your caller’s voice.
Fed up with nuisance calls?
You can block calls from an individual number or use the one touch call blocking button if you don’t want to answer a call. Or, if you’ve answered the call, you can press the call blocking button to end the call and add the number to your list of blocked numbers. Over time the phone learns which calls you do and don’t want to take.
Need an answering machine?
Save up to 60 minutes of messages and see how many messages you’ve received clearly on the screen. You can playback your messages privately through the handset or using the handsfree speaker. There’s also an option to playback your messages slowly.
Packed with great features
You can save up to 200 contacts and these can be shared between handsets if you buy a multi pack or register extra handsets. Parental control lets you set a PIN to protect calls to mobile and premium rate numbers to prevent any surprises on your bill, useful if you have children or for elderly relatives who may unknowingly dial numbers they don’t need to.
  • Block by number
    The BT4600 can block multiple individual numbers, over time, the phone learns which calls you do and don't want to take.
  • Transfer calls
    Send the call to answer phone, and then block it with ease.
BT 4600 Advanced Nuisance Call Blocker Quad - cordless phone - answering system with caller ID + 3 additional handsets - 3-way call capability
Cordless phone answering system with caller ID + 3 additional handsets
Total Number of Wireless Handsets
4
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Caller ID, Call Transfer
Display
LCD display - monochrome - Yes
Additional Handsets Qty
3
4
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
3-way
Speakerphone
Volume Control
Ring Tones
15
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm
Phone Memory
Phone Directory Capacity
200 names & numbers
Answering System
Recording Capacity
60 min
Display
Display Location
Handset
Diagonal Size
1.8"
Backlit
Headset jack
Placing / Mounting
Table-top
Power adapter, 3 phone charging stands
Dimensions & Weight (Base)
198.4 g
Dimensions & Weight (Handset)
6.1 cm
4 cm
18.3 cm
141.4 g
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
