BT4600 Big Button Premium Nuisance Call Blocker
with 100% call blocking and answer machine
An easy to use big button phone that blocks 100% of nuisance calls.
Featuring
- Works with all landline providers
- Large 1.8" screen with amber backlight
- Easy to use big buttons
- Hearing aid compatible with amplify button to boost volume
- Block 100% of nuisance calls1
- Block up to 1000 numbers
- Record up to 60 minutes of messages
- Save up to 200 contacts
- Do Not Disturb mode switches ringer off
- Handsfree speaker
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Struggling to read the screen or hear callers?
This is the ideal phone for anyone with sight, hearing or dexterity challenges. The big buttons and large screen will ease the frustration of entering numbers incorrectly or misreading messages. It’s hearing aid compatible and you can even boost the volume of your caller’s voice.
Fed up with nuisance calls?
You can block calls from an individual number or use the one touch call blocking button if you don’t want to answer a call. Or, if you’ve answered the call, you can press the call blocking button to end the call and add the number to your list of blocked numbers. Over time the phone learns which calls you do and don’t want to take.
Need an answering machine?
Save up to 60 minutes of messages and see how many messages you’ve received clearly on the screen. You can playback your messages privately through the handset or using the handsfree speaker. There’s also an option to playback your messages slowly.
Packed with great features
You can save up to 200 contacts and these can be shared between handsets if you buy a multi pack or register extra handsets. Parental control lets you set a PIN to protect calls to mobile and premium rate numbers to prevent any surprises on your bill, useful if you have children or for elderly relatives who may unknowingly dial numbers they don’t need to.
Call blocking features
The BT4600 can block up to 1000 individual numbers, meaning that you really can avoid speaking to the people you don't want to. Over time, the phone learns which calls you do and don't want to take. One touch call blocking - simply press the one touch button if you don't want to take the call, and the caller will be transferred to the answer machine. Or if you have answered the call, pressing the call blocking button will end the call and add the number to the list of blocked numbers when the Caller ID is displayed. -
Quality built-in
The modern stylish design makes this phone a great addition to any room, whilst only taking up minimal space. Large full graphic dot-matrix display with amber backlight. See instantly how many voice messages, missed calls or text messages you have. It's easy to use big buttons and large clear screen make it easy to dial quickly and accurately getting away from the frustration of miss-typing numbers on smaller keypads. This phone is ideal for anyone wanting a good looking easy to use phone, and its big buttons and easy to see backlit display makes a practical tool for more elderly customers and those with sight, hearing and dexterity challenges. Hearing aid compatible with amplify button to boost volume when you need it. -
Freedom to move in and around your house
The BT4600 has a long outdoor range of up to 300m and an indoor range of up to 50m. Talk hands-free - bringing the callers voice into the room and letting you get on with things while you chat. With the BT4600 you can talk for up to 16 hours on a full charge, or have it on standby for up to 180 hours. -
Easy to use
Save up to 200 contacts and share between handsets. See a list of who's called you, and choose which message to listen to first. Prevent surprises on your bill by PIN protecting calls to mobile, and premium rate numbers. Also useful for elderly relatives who rack up big bills unknowingly. -
Extra answer machine features
Save up to 60 minutes of messages and see how many messages you've got displayed clearly on the home scree. Listen to your messages privately through the handset, or play them using the hands-free speaker. Also includes slow playback of messages.
- BT 4600 Advanced Nuisance Call Blocker Trio - cordless phone - answering system with caller ID + 2 additional handsets - 3-way call capability
- Product Type
- Cordless phone answering system with caller ID + 2 additional handsets
- Total Number of Wireless Handsets
- 3
- Cordless Phone Standard
- DECT\GAP
- Speakerphone
- Call Services
- Caller ID, Call Transfer
- Display
- LCD display - monochrome - Yes
- 1-year warranty
- Product Type
- Additional Handsets Qty
- 2
- 3
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Location
- Handset
- Conference Call Capability
- 3-way
- Speakerphone
- Volume Control
- Ring Tones
- 15
- Polyphonic Ringer
- Indicators
- Visual ringer light
- Additional Functions
- Call timer, built-in clock, Alarm
Phone Memory
- Phone Directory Capacity
- 200 names & numbers
Answering System
- Recording Capacity
- 60 min
Display
- Display Location
- Handset
- Backlit
- Connections
- Headset jack
- Placing / Mounting
- Table-top
- Included Accessories
- Power adapter, 2 phone charging stands
Dimensions & Weight (Base)
- 198.4 g
Dimensions & Weight (Handset)
- 6.1 cm
- 4 cm
- 18.3 cm
- 141.4 g
- Limited warranty - 1 year
