BT Whole Home Wi-Fi Trio and Smart Home Cam Bundle
Quicklinx: DV7CWS00 Mfr#: 097140
Select:
  • Trio
  • IEEE 802.11n
BT's Whole Home Wi-Fi and Smart Home Cam offer better connectivity, peace of mind and comfort at home
  • Three discs create a complete Wi-Fi network for medium to large homes, removing Wi-Fi dead spots
  • Use the app to see who is online, pause the internet, schedule Wi-Fi access including bedtimes and create a guest network
  • Smart Cam with HD quality video/ Night vision/ Two way audio/ Safe and secure/ Easy 3 step setup
  • Motion detection sensor, with alerts and snapshots to your mobile device/ Option to add up to 10 cameras
  • Works with iOS and Android devices/ Free App on Apple App Store or Google Play Store
BT's intelligent new smart home camera detects motion and sends instant alerts to your smartphone via the app. Get peace of mind your home's safe, wherever you are! With Wi-Fi connectivity proving to be more important in our daily lives than ever before, a fast and reliable connection is vital for smart home devices to "talk" to each other how they should; and they don't come any better than BT Whole Home Wi-Fi.
BT has been at the heart of connecting people for decades. BT's Whole Home Wi-Fi and Smart Home Cam offer better connectivity, peace of mind and comfort at home - whether home or away - and they do it securely. BT takes security seriously, that's why the Smart Home Cam and Whole Home Wi-Fi come with encryption and a Secure Guest Network. Plus, for extra control over your devices, both products come with their easy-to-use smartphone apps so you're always in charge of your home. The way it should be.
Whole Home Wi-Fi
Internet from the loft to the cellar. And in every room between.
Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens.
Wherever you are in your home, Whole Home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they're always connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network.
Works with all broadband providers
You don't need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you'll have wi-fi all around your home in minutes.
Click here to learn more about Whole Home Wi-Fi.
Smart Home Cam
Peace of mind when you're away from home
Get alerts when there's activity with free cloud storage. The BT Smart Home cam is integrated with a clever PIR sensor which detects motion and sends instant alerts to your smartphone via the app. The camera takes a snapshot each time it detects activity and saves it onto the cloud for 30 days for easy access. You can also watch the live video stream in HD and record directly to your smartphone or home cam microSD card using the app (microSD card not provided).
Click here to learn more about Smart Home Cam.
  • Internet from the loft to the cellar and in every room between
    Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens. Wherever you are in your home, whole home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they're always connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network.
  • Works with any broadband provider
    You don't need to have broadband with BT to use whole home Wi-Fi. Just connect the discs to your existing router or hub using the app and you'll have Wi-Fi all around your home in minutes.
  • Peace of mind when you're away from home
    Get alerts when there's activity. The BT smart home cam is integrated with a clever PIR sensor which detects motion and sends instant alerts to your smartphone via the app. The camera takes a snapshot each time it detects activity and saves it. You can also watch the live video stream in HD and record directly to your smartphone using the app.
BT Whole Home Wi-Fi - radio access point - Wi-Fi 5 - with Smart Home Cam
Radio access point
Packaged Quantity
3 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz, 5 GHz
16.5 cm x 7.7 cm x 16.5 cm
415 g
3-year warranty
Bundled with
Smart Home Cam
Packaged Quantity
Radio access point
16.5 cm
7.7 cm
16.5 cm
415 g
Bundled with
Smart Home Cam
External
Wireless
Data Transfer Rate
1733 Mbps
Line Coding Format
256 QAM
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
WPS, starting, connection status
Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
Antenna
Internal
Antenna Qty
4
1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
External power adapter
7.09 Watt
Limited warranty - 3 years
10 - 85%
