Digital Answer MachineThe BT Verve 450 can digitally record up to 15 minutes of messages or up to 59 messages. Each incoming message can last up to a maximum of 1 minute. | |
Caller DisplayIf you have subscribed to a Caller Display Service, you will be able to see your caller’s number on your handset display (provided it is not withheld) prior to answering the call. If your caller’s name is stored in the directory and a number match is found, you will see the caller’s name on the display instead. | |
Wireless RangeThe BT Verve 450 has a range of 300 metres outdoors when there is a clear line of sight between the base and handset. With the base indoors and handset either indoors or outdoors, the range will normally be up to 50 metres. |
PhonebookStores 200 contact numbers for easy dialling. Store a directory entry then copy it – or the entire phonebook – to another BT Verve 450 handset. |
Battery LifeIn ideal conditions, a fully charged battery should give up to 10 hours talk time or 100 hours standby time on a single charge. |
HandsfreeHandsfree lets you talk to your caller without holding the handset. It also enables other people in the room to listen to your conversation over the loudspeaker. |
Size of Call ListThe Calls list holds up to 20 numbers. The date and time of the call is also stored if available. |
GAP CompatibleYou can use up to five BT Verve 450 additional handsets with the BT Verve 450 base to extend your phone system without needing to install extension sockets for each new phone. |
- BT Verve 450 Quad - cordless phone - answering system with caller ID + 3 additional handsets
- Product Type
- Cordless phone answering system with caller ID + 3 additional handsets
- Total Number of Wireless Handsets
- 4
- Cordless Phone Standard
- DECT\GAP
- Answering System
- Digital
- Speakerphone
- Caller ID
- Call Services
- Caller ID
- Display
- LCD display - monochrome - Yes
- Display Features
- Inverted
- Display (2nd)
- LED display - monochrome
- Product Type
- Additional Handsets Qty
- 3
- 4
Phone Features
- DECT\GAP
- Call Services
- Caller ID
- Caller ID Type
- Caller ID
- Max Handsets Supported
- 5
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Short Messaging Service (SMS)
- Volume Control
- Ringer Control
- Additional Functions
- Call timer, built-in clock, Alarm
Phone Memory
- Phone Directory Capacity
- 200 names & numbers
Answering System
- Answering System Type
- Digital
- Recording Capacity
- 15 min
- Message Counter Display
- Services
- Call Screening
Display
- Display Location
- Handset
- Backlit
- Inverted
Display (2nd)
- LED display
- Colour Support
- Monochrome
- Display Location
- Base
- Aerial
- Internal
- Included Accessories
- Power adapter, phone charging stand
- Phone charging stand + power adaptor - external
- Technology
- Rechargeable
- Talk Time
- Up to 600 min
- Standby Time
- Up to 100 h
