Product Overview:
The BT Synergy 6500
- Digital answering with up to 30 minutes recording time
The BT Synergy 6500 can digitally record up to 30 minutes of messages or up to 59 messages. Each message can last up to a maximum of 3 minutes. As well as recording incoming messages, you can record memos for other users.
The BT Synergy 6500 comes with two pre-recorded outgoing messages (answer & record and answer only), or users can record their own.
- 20 Last number redial
The last 20 telephone numbers called are saved to a list for easy redial. You can then select any of the numbers to redial, delete or copy to the phonebook.
- 250 Entry phonebook
Up to 250 names and numbers can be stored in the phonebook to make dialling quick and easy. Different ring tones can also be selected for phonebook entries.
- Caller Display with 30 number calls list
See who is calling you before you answer the phone. The calls list holds details of the last 30 callers, including the phone number and time and date of the call.
- Text messaging with 50 text memory
The BT Synergy 6500 can send and receive text messages from participating mobile networks and compatible landline telephones in the UK.
You must subscribe to your Network Provider's Caller Display service so that you can use text messaging and you must not withhold your telephone number. A quarterly fee may be payable, please contact your network provider for more details.
- Handsfree handset speaker
Handsfree lets you talk to callers without holding the handset. It also enables other people in the room to listen to your conversations over the loudspeaker.
- Call Waiting
Call waiting alerts you if someone tries to call you while you are already on the phone. During a call, the BT Synergy 6500 will project soft beep in the earpiece and the display shows the number of the caller or the name if it matches an entry in your phonebook.
You must subscribe to your network's Caller Display service for Call Waiting to work. A quarterly fee may be payable.
- Add extra handsets without adding phone sockets
You can use up to five BT Synergy additional handsets with your BT Synergy 6500 base to extend your phone system without needing to install extension sockets for each new phone.
Your BT Synergy 6500 handset can also be registered to up to 3 other bases. You can then select the base you would prefer to use.
- Have you got enough handsets?
The BT Graphite 6500 range is available in 1, 2, 3 or 4-Pack versions. You can have a phone in each room - without the need for extra wiring or phone sockets.
Full Specification:
- 250 name and number memories.
- Ringer volume control.
- Speaker volume control.
- Hands-free speakerphone.
- 20 ringtones.
- Up to 10 hours talktime.
- Up to 100 hours standby time.
- Up to 50m indoor range and up to 300m outdoor range.
- 30 call log.
- Call transfer.
- Call waiting.
- Call timer.
- Caller display (dependent on service provider specifications).
- Last number redial.
- Incoming ring personalisation.
- SMS text facility.
- Sim card read and write.
- Secrecy feature.
- Zoom dialling.
- 4 colour line display.
- Keypad lock on handset.
- Alarm.
- Clock.
Answer machine features:
- 2 pre-recorded messages.
- 30 mins recording time.
- Message playback from base and handset.
- Personalised recording facility.
