BT Smart Home Cam
BT Smart Home Cam
Quicklinx: DQN6WS00 Mfr#: 088438
Key features:
  • 720p HD video streaming - Clear high quality live video streaming
  • 30 day free cloud storage for snapshots - Access 30 day worth of motion detection snapshots from anywhere
  • Motion alerts - PIR Motion Sensor triggers alerts, sending an image directly to your smartphone
  • Night vision - See things clearly even in complete darkness
  • Record clips to your smart device - Record moments that matter and save directly to your smartphone
  • 120 degree viewing angle
  • MicroSD card slot for recording motion detection video - up to 32 GB storage, giving you 3 months of motion events (microSD card not included)*
  • Two way audio - Hear and talk back to those at home whilst you are away
  • Easy 3 step setup - Download the app, connect the camera to the wifi router and off you go!
  • Wall mountable
  • Safe and secure - Our live video stream is secured with AES 128 bit encryption
Peace of mind when you're away from home
Get alerts when there's activity with free cloud storage. The BT Smart Home cam is integrated with a clever PIR sensor which detects motion and sends instant alerts to your smartphone via the app. The camera takes a snapshot each time it detects activity and saves it onto the cloud for 30 days for easy access. You can also watch the live video stream in HD and record directly to your smartphone or home cam microSD card using the app (microSD card not provided).
App Screen
See them when they can't see you!
Our Smart Home cam comes with advanced night vision with multiple IR sensors. Which means that you can get excellent quality night video streaming even in complete darkness. So you can see what your pets are up to when you are not around!
Night Vision
Feel like you are there
Not only can you keep an eye on your home but you can also listen to live audio. With two way talk back you can check in on the family if they are home before you and see how their day was.
Tablet
*(assuming 10 motion triggers per day @ 30 seconds)
** Please note you will need to create a new account to use the BT Smart Controls app, follow the easy guidelines on the app log-in screen. Existing BT.com account details will not be valid.**
  • Complete control
    Get motion alerts and check what's going on at home using live HD streaming, even when the lights are off.
  • Keeping an eye on your home
    Keep an eye on your home and receive motion alerts when you're not there.
  • Simple set-up
    Use the app to set-up your camera in your home.
BT Smart Home Cam - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: two-way audio capability
Wireless
Camera
Colour - Day&Night
Motion Detection
Wi-Fi
Motion Detection Technology, snapshot function
Audio Support
Wireless
Camera
Colour - Day&Night - fixed - indoor
Motion Detection
Network Interface
Wi-Fi
Supported Memory Cards
SD Memory Card
Resources
The following resources are available for the BT Smart Home Cam
