BT Refurbished Whole Home Wi-Fi 6 - Three Disc
Quicklinx: H1CYWS00 Mfr#: 114342-REFURB
  • IEEE 802.11n
Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Push faster, stronger wi-fi to every corner of your home. Using the latest AX6600 Tri-band Wi-Fi technology to create a complete Wi-Fi network.
  • Complete control
    See who's online and connected to your Wi-Fi, pause the internet for everyone or by individual devices, set schedules for the kids' bedtimes and create a separate Wi-Fi network for guests.
  • Super smart
    Intelligent Wi-Fi technology automatically connects you to the fastest and strongest signal as you move from room to room.
BT Mini Whole Home Wi-Fi 6 - radio access point - Wi-Fi 6
Radio access point
Packaged Quantity
3 (specifications are for single item)
External
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands)
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 4.8 Gbps
AC 230 V (50 Hz)
18.2 cm x 7.1 cm x 18.2 cm
468 g
Packaged Quantity
Radio access point
18.2 cm
7.1 cm
18.2 cm
468 g
External
Wireless
Frequency Band
Performance
Roaming function, Wi-Fi Protected Setup (WPS), reset button, band steering, Backhaul Technology, 2x2 MIMO technology, 4x4 MIMO technology
Encryption Algorithm
AES, WPA, WPA2, WPA3
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v, IEEE 802.11ax
Aerial
Antenna
Internal
2 x 1000Base-T - RJ-45
1 x network cable
External power adapter
AC 230 V (50 Hz)
11.4 Watt
Shipping Width
23.35 cm
Shipping Depth
20.5 cm
Shipping Height
26 cm
45 °C
10 - 90%
