BT Paragon 650 Digital Answering Machine
Quicklinx: 95R9WS00 Mfr#: 032116
The BT Paragon has a built-in SIM card reader/writer so there's no need to re-enter all your contacts into your new phone. Just insert your mobile's SIM card into the BT Paragon and copy all the numbers from there. It's also a great way to keep a backup of the numbers stored on your mobile phone.
The answering machine has two pre-recorded male and female outgoing messages or you can record your own. You can playback messages via the loudspeaker or privately through the handset and you can screen calls. There is a memo feature so you can leave messages for other handset users and you can access your answering machine remotely and listen to your messages when you are away from home.
Send and receive text messages from your BT Paragon phone. A flashing light on the base, a message on the display and an audible alert indicate that new text messages have been received.
Your BT Paragon phone can store up to 200 of your most frequently used names and numbers to make dialing quick and easy. If you subscribe to a caller display service you can also assign group ringtones when you store directory entries - the assigned ringtone will then play when someone from a particular group calls you.
See who is calling you before you answer the phone. The calls list holds details of your last 50 callers, including the phone number and time and date of the call. If a number matches a stored directory entry, the caller's name is displayed as well as the number.
  • Mobile phone SIM card reader/writer
  • Answering machine with up to 32 minutes digital recording time
  • Text messaging with message storage space
  • 200 name and number directory
  • Caller display with 50 number calls list
BT Paragon 650 - corded phone - answering system with caller ID/call waiting
Corded phone answering system with caller ID/call waiting
Answering System
Digital
Speakerphone
Caller ID
Voice Mail Capability
Call Services
Voice Mail, Caller ID, Call Waiting
Speed Dial Capacity
3
Display
LCD display - monochrome - Yes
Body Colour
Body Colour
Phone Features
Call Services
Caller ID Type
Caller ID/call waiting
Dialer Type
Keypad
Dialer Location
Base
Dialing Modes
Pulse, tone
Speakerphone
Short Messaging Service (SMS)
Menu Operation
Function Buttons
Speakerphone button, recall button, directory button, memory pause button
Volume Control
Ringer Control
Ring Tones
15
Polyphonic Ringer
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Time/Day Stamp, built-in calendar
Additional Features
Tone control, built-in SIM card reader
Phone Memory
Phone Directory Capacity
200 names & numbers
Dialed Calls Memory
10
Speed Dial Capacity
3
Caller ID Memory
50 names & numbers
SMS Memory Capacity
Up to 40 SMS
Answering System
Answering System Type
Digital
Outgoing Announcements Qty
2
Recording Capacity
32 min
Memo Record Function
Message Counter Display
Services
Toll Saver, Call Screening
Voice Prompts
Display
Display Location
Base
Line Qty
4
Display Information
Alarm mode, Handsfree
Backlit
Headset jack , Data port
Hearing Aid Compatible
Phone line cable
Power adapter
Power adapter - external
