BT Hub Phone 2.1
BT Hub Phone 2.1
Quicklinx: 567NWS00 Mfr#: 044662
The New Hub Phone slots neatly into your BT Home Hub 2.0 and gives you UK Evening and Weekend calls at no extra cost - and cheap calls at other times via BT Broadband talk.
It is a fully featured handset which will operate anywhere within the range of your homehub.
  • Broadband Talk (BBT) compatible
  • Hi-dS (High definition sound)
  • 150 entry shared contacts list
  • 50 entry handset contacts list
  • Up to 4 numbers per contact
  • Handsfree speaker
  • 50 number calls list of received and missed calls
  • 3 handsets can make simultaneous calls from one BBT number
  • Headset port
  • Caller ID and Call Waiting supported
  • 25 last number redial
  • 9 speed dial entries
  • 4 line high resolution inverse LCD
  • 10 polyphonic ringer melodies
  • Ringer volume control
  • Secrecy
  • Charger can be plugged directly into the mains or into a BT Home Hub 2.0
  • Access to BT 1571 service
  • Earpiece volume control
  • GAP compatible
  • Alarm function
  • Internal calls
  • Call transfer
  • Auto talk
  • Paging handsets
  • Handset power On/Off
  • Keypad lock
  • Out of range and low battery warnings
  • Up to 10 hour talk & 100 hour standby time
  • Up to 50m indoor, 300m outdoor range
** Handset must be registered to BT Home Hub 2.0 for all features to be accessible
Resources
The following resources are available for the BT Hub Phone 2.1
