BT Dual-Band Wi-Fi Extender 600
Quicklinx: 9WW6WS00 Mfr#: 075716
  • IEEE 802.11n
  • Extend your existing WiFi coverage to areas your router can't reach
  • Works with all Broadband providers
  • Upgrade to dual band WiFi for a more reliable connection
  • Compatible with non Dual-Band devices
  • High speed data transfer (N600) for downloading music, streaming HD video content, or playing online games
  • Easy set-up
  • Simple push-button connection to your Hub/Router
Works with any Broadband provider
BT's Dual-Band Wi-Fi Extender 600 Kit has been designed to work with any service provider to make sure everyone can make the most of their broadband around their home.
What does BT's Dual-Band Wi-Fi Extender 600 give you?
Extend the range of your Wi-Fi around your home and enjoy the full broadband experience. **Easy set-up - No install necessary, just connect to your router and access the internet in minutes!**
Everyone loves to be online; and why should you settle for anything other than the complete broadband experience? With BT's Dual-Band Wi-Fi Extender 600, you are able to extend the range of you wireless broadband and connect all your wireless devices wherever and whenever you like.
Ideal for HD/3D streaming, online gaming or faster downloads; BT's Dual-Band Wi-Fi Extender 600 supports all your online needs.
Simple to use
The Dual-Band Wi-Fi Extender 600 from BT is easy to use. Simply plug into your wall socket and link with your router and you are ready to enjoy an extended wireless broadband experience.
Increase your Wi-Fi range
BT's Dual-Band Wi-Fi Extender 600 allows you to extend the range of your wireless broadband, meaning dead-spots are a thing of the past.
What is Dual-Band wireless technology?
Dual-Band wireless technology is a second, different, wi-fi signal that your devices will connect to automatically if compatible. If not, use the BT Dual-Band Wi-Fi Dongle 600 to take advantage of the improved speed and reliability on offer.
The BT connectivity range
BT's Dual-Band Wi-Fi Extender 600 is just one part of BT's new connectivity range, which has been designed to solve all connectivity issues to ensure everyone makes the most of their broadband around their home. Other products include Broadband Extenders, Dongles, Dual-Band upgrade kits and switches, ensuring all your major connectivity requirements are covered.
Box Contains
  • Dual-Band Wi-Fi Extender 600
  • Ethernet Cable
  • User Guide
  • Extending Wi-Fi
    Extend the range of your Wi-Fi around your home.
  • Dual-Band reliability and speed
    Connect your Dual-Band Wi-Fi Extender to your existing wireless broadband.
  • Uninterrupted media streaming
    Perfect for downloading music, streaming HD video content or for playing online games.
BT Dual-Band Wi-Fi Extender 600 - Wi-Fi range extender - Wi-Fi
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz, 5 GHz
AC 230V (50 Hz)
7.1 cm x 7.7 cm x 12.1 cm
167.4 g
7.1 cm
7.7 cm
12.1 cm
167.4 g
External
Wireless
Frequency Band
2.4 GHz, 5 GHz
Status Indicators
Power, link/activity, WPS
Reset button
Encryption Algorithm
AES, TKIP, WPA, WPA2
Aerial
Antenna
Internal
1 x 100Base-TX - RJ-45
1 x network cable
Internal power supply
AC 230V (50 Hz)
12 Watt
45 °C
10 - 90%
Resources
The following resources are available for the BT Dual-Band Wi-Fi Extender 600
