Decor 2200
with handsfree speaker
An easy to use corded phone that’s compatible with hearing aids.
Featuring
- Works with all landline providers
- Easy to set up and simple to use
- Big buttons
- Excellent sound quality
- Hearing aid compatible
- Save up to 50 contacts
- Handsfree speaker
- Secrecy feature, put your caller on mute
- Last number redial
- See who’s calling before you pick up1
- Calls light indicator
- One touch 1571 button2
1You need to have a Caller Display service from your network provider to see who’s calling. Charges may apply.
2To use the 1571 voicemail feature you must subscribe to your network provider’s network answering service and batteries must be installed.
Packed with great features
For easy dialling, you can save up to 50 contacts in the phonebook and redial the last number called. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker. The green light on the handsfree button will illuminate when handsfree mode is on.
Want to see who’s calling before you pick up?1
If you subscribe to a Caller Display service, you’ll be able to see your caller’s number on the handset display (provided it’s not withheld) before you answer the call. If your caller’s name is stored in your phonebook and it matches the number calling, you’ll see the caller’s name displayed instead. There’s a Calls list that holds the numbers (and names if there’s a match with the phonebook) of your last 30 received calls.
Easy access to BT 15712
If you’ve subscribed to your network’s answering service like BT Answer 1571 or Call Minder, you can press the 1571 button to easily access the service and listen to your messages. The green light will flash when you have new messages waiting.
2 To use the 1571 voicemail feature you must subscribe to your network provider’s network answering service and batteries must be
- BT Decor 2200 - corded phone with caller ID/call waiting
- Product Type
- Corded phone with caller ID/call waiting
- Speakerphone
- Caller ID
- Call Services
- Caller ID, Call Waiting, Message Waiting Capability
- Display
- LCD display - monochrome
- Body Colour
- White
- 1-year warranty
- Product Type
- Corded phone
- Body Colour
- White
Phone Features
- Call Services
- Caller ID Type
- Caller ID/call waiting
- Dialer Type
- Keypad
- Dialer Location
- Base
- Speakerphone
- Menu Operation
- Function Buttons
- Speakerphone button, recall button, directory button, navigator key, 1571, mute button, auto redial button
- Volume Control
- Ringer Control
- Ring Tones
- 3
- Indicators
- Visual ringer light, voice message waiting indicator
- Additional Functions
- Call timer, built-in clock, built-in calendar
Phone Memory
- Phone Directory Capacity
- 50 names & numbers
- Caller ID Memory
- 30 names & numbers
Display
- Display Location
- Base
- Line Qty
- 3
- Hearing Aid Compatible
- Cables Included
- Phone line cable
- Battery
- 4 x battery - AA type
- Included Qty
- 4
Dimensions & Weight (Base)
- 20 cm
- 16 cm
- 9 cm
- 499 g
- Limited warranty - 1 year
