With ten number memory, Caller display, and an inductive coupler, the BT Decor 1200 is a great business or home office phone.
Top Features
- 10 number memory
- Handsfree
- Volume control
- Message waiting Indicator
- Inductive coupler
- BT Services programmed into directory (can be overwritten)
In order to see who is calling, you will need to subscribe to the BT Caller Display Service for the caller display function on this phone to be activated. The Caller Display Service is available at no extra cost when you sign up to BT's Privacy at Home service. It helps you take control of incoming calls with BT Caller Display and also helps you reduce unwanted sales calls with Telephone Preference Service
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
- BT Decor 1200 - corded phone with caller ID
- Product Type
- Corded phone with caller ID
- Speakerphone
- Caller ID
- Call Services
- Caller ID
- Speed Dial Capacity
- 10
- Display
- LCD display - monochrome
- Body Colour
- Chalk white
- 1-year warranty
- Product Type
- Corded phone
- Body Colour
- Chalk white
Phone Features
- Call Services
- Caller ID
- Caller ID Type
- Caller ID
- Dialer Type
- Keypad
- Dialer Location
- Base
- Speakerphone
- Function Buttons
- Recall button, 1571, memory pause button, mute button
- Volume Control
- Ringer Control
- Indicators
- New call indicator
- Additional Functions
- Built-in clock
Phone Memory
- Phone Directory Capacity
- 50 names & numbers
- Dialed Calls Memory
- 1
- 10
- One-Touch Dial Button Qty
- 3
Display
- Display Location
- Base
- Placing / Mounting
- Wall-mountable, table-top
- Limited warranty - 1 year
