The BT Decor 1300 has a two line LCD screen with contrast control, Caller Display, a clock with date, day and month. It has features such as polyphonic ring tones, 100 names and numbers directory, control, time and date stamp, store, secrecy, pause and recall buttons. Wall mountable, it is PBX compatible and supports TouchTone dialing.
Key Features:
- LCD screen
- Ring indicator light
- Polyphonic ring tones - 0
- Pause
- Recall
- Last number redial
- Ringer hi-low-off
- Secrecy
- Mute button
- Store button
- Touch tone dialling compatible
- Wall mountable
- 1571 network message detection
- Speech amplification volume control
- Speaker Volume Control
- Pre-dialling facility
*In order to see who is calling you will need to subscribe to the BT Caller Display Service which is available when you sign up to www.bt.com/btprivacy BT residential customers making some calls on the BT network can opt in to receive Caller Display at no extra charge, subject to availability. Analogue lines only. Numbers will not be registered if the call is from payphones, some switchboards, and non-BT networks or where a caller's number is withheld.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
- BT Decor 1300 - corded phone with caller ID
- Product Type
- Corded phone with caller ID
- Speakerphone
- Caller ID
- Call Services
- Caller ID
- Speed Dial Capacity
- 10
- Display
- LCD display - monochrome
- Body Colour
- Arctic grey
- 1-year warranty
- Product Type
- Corded phone
- Body Colour
- Arctic grey
Phone Features
- Call Services
- Caller ID
- Caller ID Type
- Caller ID
- Dialer Type
- Keypad
- Dialer Location
- Base
- Speakerphone
- Menu Operation
- Function Buttons
- Recall button, 1571, memory pause button, mute button
- Volume Control
- Ringer Control
- Additional Functions
- Call timer, built-in clock, Time/Day Stamp
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- Dialed Calls Memory
- 1
- 10
Display
- Display Location
- Base
- Line Qty
- 2
- Placing / Mounting
- Wall-mountable
- Limited warranty - 1 year
