Advanced Phone Z with 100% nuisance call blocking and answer machine
The Advanced Phone Z, powered by trueCall’s award winning technology. Have complete control over which calls you want to take and those you want to block.
Nuisance Call blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls.
- Block up to 1000 numbers
- Excellent sound quality
- Easy set up
- Handsfree speaker
- Long range reception, up to 300m outdoors, 50m indoors
- 22 hours of talking OR 240 hours standby time
- See and hear if you have a second call waiting
- Easy to read screen shows when you have messages
- Dedicated Call Block Button
- Save up to 200 contacts
- Redial any of the last 30 calls you made
- Record up to 30 minutes of messages
- 1.8 inch monochrone black and white screen
Nuisance ?all blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls. -
Get the most out of your phone straight away with easy to use menu. And enjoy high quality clear calls.
- BT Advanced Phone Z Quad Pack - cordless phone - answering system with caller ID + 3 additional handsets
- Product Type
- Cordless phone answering system with caller ID + 3 additional handsets
- Total Number of Wireless Handsets
- 4
- Cordless Phone Standard
- DECT\GAP
- Speakerphone
- Call Services
- Call Waiting, Call Block
- Display
- LCD display - monochrome - Yes
- Product Type
- Additional Handsets Qty
- 3
- 4
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Volume Control
- Additional Functions
- Call timer, built-in clock, Alarm
Phone Memory
- Phone Directory Capacity
- 200 names & numbers
- Caller ID Memory
- 30 names & numbers
Answering System
- Recording Capacity
- 30 min
Display
- Display Location
- Handset
- Diagonal Size
- 1.8"
- Backlit
- Placing / Mounting
- Table-top
