The BT3880 Phone Nuisance Call Blocker, gives you back control over which calls you want to take and which you want to block.
- Blocks up to 20 numbers*
- Excellent sound quality
- Easy set-up
- Long range reception, up to 300m outdoors, 50m indoors
- Up to 10 hours of talking or 100 hours standby time
- See and hear if you have a second call waiting
- See who's calling before you pick up
- Handsfree
- Do Not Disturb mode
- Save up to 50 contacts
- Redial any of the last 20 calls you made
- Hands-free
- 1.6 inch amber screen
*You need to have a Caller Display service from your network provider to block nuisance calls and for text messaging features. Charges may apply.
