Brother QL-1050 Label Printer
Quicklinx: 8CRPWS00 Mfr#: QL1050ZU1
Label printers now need to be more versatile and robust than ever to keep up with businesses like yours – and the QL-1050 is more than capable.
Offering high quality labels in sizes from 12mm up to a massive 102mm wide, the 300dpi resolution is perfect for consistent barcode and logo reproduction. And with printing speeds of up to 69 labels per minute and a built-in heavy-duty automatic cutter, high volumes are no problem.
USB and RS-232 serial ports allow you to simply connect this versatile machine with any relevant equipment, and you can print directly from MS Word, Excel and Outlook.
With durability built in, the QL-1050 is a truly dependable solution.
  • Efficient printing speed
    The Brother QL-1050 features a maximum printing speed of 110 mm/s, ensuring quick delivery of labels to keep up with demanding workflows.
  • Variety of barcode support
    This printer supports numerous barcodes including Code 128, EAN/JAN-13, and PDF417, catering to a range of labeling requirements.
  • Flexible media compatibility
    It accommodates roll media up to 10.2 cm in size, providing flexibility for labels and continuous forms in different applications.
  • Clear and concise output
    Deliver sharp monochrome labels with quality that enhances visibility and readability, essential for effective labeling.
  • Simple connectivity
    The USB interface allows for direct and reliable connection to computers, streamlining the printing process without complications.
Brother QL-1050 - label printer - B/W - direct thermal
Printer Type
Label printer - direct thermal - B/W
1.7 kg
United Kingdom
Max Media Size
Roll (10.2cm)
Max Media Size (Custom)
102 mm
Print Speed
Up to 69 labels/min , Up to 110 mm/sec
Max Resolution (B&W)
300 dpi
Cutter
USB, serial
Language Simulation
EPSON ESC/P, EPSON ESC/P Raster
Barcodes
Code 39, UCC/EAN-128, QR code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, PDF417, ITF, Micro QR code
Media Type
Labels, continuous forms
Compatible Tapes
DK tape
Fonts
Brussels, Helsinki, San Diego, Letter Gothic
Character Sizes
24 points, 48 points, 32 points
Styles & Effects
Bold, italic bold, italic outline, normal, vertical, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround
Microsoft Windows 2000 Professional, Microsoft Windows XP, Apple MacOS X 10.1, Apple MacOS X on Intel 10.4.4 or later, Apple MacOS X Server 10.4.7
Microsoft Certification
Works with Windows Vista
17 cm x 22 cm x 14.8 cm
Printer Type
Label printer - direct thermal - monochrome
United Kingdom
Printer
Print Speed
Built-in Devices
Cutter
Wired
USB, serial
300 dpi
Language Simulation
Fonts
Character Sizes
Styles & Effects
Auto Cutter
Repeating Printing
500 copies
Fonts Included
1 x TrueType
Barcodes
Media Handling
Media Type
Compatible Tapes
DK tape
Max Media Size
Roll (10.2cm)
102 mm
Media Sizes
Roll (2.9 cm), Roll (1.2 cm), Roll (10.2cm), Roll (6.2 cm)
Max Printing Width
98.6 mm
1 x USB - 4 pin USB Type B , 1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
Power supply - internal
Software Included
Drivers & Utilities, Brother P-touch Editor
System Requirements Details
Windows 2000/XP - RAM 128 MB - HD 70 MB , MacOS X 10.1 or later - RAM 64 MB - HD 100 MB
10 °C
35 °C
20 - 80%
17 cm
22 cm
14.8 cm
1.7 kg
Ink (7)
8CRP Brother Large Address Labels In Stock £7.69
8CRP Brother DK Continuous White Labels In Stock £13.81
8CRP Brother Shipping 62 x 100mm 300 Labels In Stock £11.04
8CRP Brother P-TOUCH Yellow Paper- 62mm In Stock £13.70
8CRP Brother p-touch White Paper - 62mm In Stock £12.51
8CRP Brother Paper Roll (6.2 cm x 30.5 m) In Stock £10.09
8CRP Brother Non Adhesive Paper Tape 54mm In Stock £11.87
Other bundles (2)
8CRP Brother BROTHER DK-22212 TAPE 62MM WH. In Stock £33.17
8CRP Brother P-TOUCH TAPE PAPER 29MMX30.48M In Stock £6.51
