The PT-D600VP is ideal for clear and durable workplace labelling up to 24 mm wide. It is perfect for organisation of workspaces, clear identification of equipment, assets and filing, as well as creation of basic instructional or warning notices. The compact and sleek new design ensures that it fits at any office workstation. It has a multitude of great benefits that help make the workplace more efficient and eliminate those little irritations that have staff tearing their hair out.
Full-color graphical display
You can view label appearance before printing. -
PC-connectable
You can use stand-alone, or connected to a PC or Mac for added design capabilities. -
Split-back tapes
It uses durable, easy-peel tapes in 5 different widths up to 24mm (approx. 1"). -
Supports large character printing
You can print up to 8 font sizes. -
Multi-line labels
It prints labels with up to 7 lines of text. -
Personalize labels
It uses 14 fonts, 11 styles, 99 frames, over 600 symbols, plus barcodes. -
Large memory
Save up to 99 commonly used labels and help save time with reprinting. -
Specialty templates
Print labels for asset management, cable labeling - even add time and date. -
High-resolution PC-printing
It is used for crisp graphic, barcode, and logo printing. -
Super-fast print speeds
You can print fast with Automatic Tape Cutter for high-volume jobs.
- Brother P-Touch PT-D600VP - labelmaker - B/W - thermal transfer
- Printer Type
- Labelmaker - thermal transfer - B/W
- 950 g
- Max Media Size
- Roll (2.4 cm)
- Max Media Size (Custom)
- 24 mm
- Print Speed
- Up to 30 mm/sec
- Cutter
- Interface
- USB
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Fonts
- 14 fonts
- Styles & Effects
- Vertical, underline
- 7 line printing
- Display Resolution
- 3 lines x 20 characters / 320 x 120
- Battery
- Required 6 x AA type Alkaline Included Qty 0
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Apple MacOS X 10.7 - 10.9
- Enclosure Colour
- Black
- 20.1 cm x 19.2 cm x 8.6 cm
- Printer Type
- Labelmaker - thermal transfer - monochrome
- Enclosure Colour
- Black
Printer
- Print Speed
- Up to 30 mm/sec
- Built-in Devices
- Preview screen, character keyboard
- Interface
- USB
- Fonts
- 14 fonts
- Styles & Effects
- 7 line printing
- Auto Cutter
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape
- Max Media Size
- Roll (2.4 cm)
- 24 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
- Max Printing Width
- 18 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (2.4 cm)
- Connections
- 1 x USB
- Included Accessories
- Carrying case
- Cables Included
- 1 x USB cable
- Media Included
- 1 24 mm x 4 m black on white TZe laminated tape cassette
- Power Device
- Power adapter
- AA type - Alkaline
- Required Qty
- 6
- Included
- 0
- OS Required
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
- 20.1 cm
- 19.2 cm
- 8.6 cm
- 950 g
Ink (18)
Brother TZES221 Black on White 9mm | In Stock | £10.44 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.59 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.80 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £11.23 |
Brother TZES651 24mm Black on Yellow | In Stock | £15.22 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.38 |
Brother Tape Black on Yellow 6mm | In Stock | £7.52 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.20 |
Brother Tape Black on Yellow 12mm | In Stock | £11.47 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.48 |
Brother 12mm Black on White Tape | In Stock | £11.49 |
Brother Tape Black on Clear 9mm | In Stock | £7.58 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £9.93 |
Brother 12mm Blue on White Tape | In Stock | £9.93 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.81 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.48 |
Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE | In Stock | £16.80 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.49 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.38 |
