Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE
Quicklinx: CJGWWS00 Mfr#: Tze 451
£17.19 ex VAT
£20.62 inc VAT
This tape features Brother's exclusive laminated tape process and standard adhesive. The Brother TZE451 is perfect for everyday applications and is best suited for smooth flat surfaces. These labels stay on under normal indoor and outdoor use, including hot and cold environments.
  • P-touch TZ label tested to the extreme
    Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight.
  • Abrasion resistant P-touch TZ label
    Brother's patented tape technology ensures that Brother P-touch laminated label can withstand even heavy abrasion.
  • Temperature resistant P-touch TZ label
    Whether you want to use the label in freezing conditions or extremely warm environments, Brother P-touch laminated label has been designed to last.
  • Fade resistant P-touch TZ label
    Wherever you use P-touch laminated label, it will stay as clear and legible as the day it was applied.
  • Water and chemical resistant P-touch TZ label
    Testing TZ label 'to the extreme' has found it to be waterproof and resistant to chemical spill.
Brother TZe-451 - laminated tape - 1 cassette(s) - Roll (2.4 cm x 8 m)
Laminated tape
Adhesive Type
Standard adhesive
Media Size
Roll (2.4 cm x 8 m)
Printing Technology
Thermal transfer
Media Colour
Black on red
Included Qty
1 cassette(s)
Compatible with
Brother PT-D600; P-Touch PT-1400, 1500, 1600, 1650, 1900, 1910, 1950, 1960, 2110, 2200, 2210, 2300, 2310, 2400, 2420, 2430, 2480, 2500, 2600, 2610, 2700, 2710, 2730, 3600, 550, 7500, 7600, 9200, 9500, 9600, 9700, 9800, D600, D800, E500, E550, E800, H500, P700, P750, P900, P950; P-Touch EDGE PT-P750
Media
Media Type
Laminated tape
Adhesive Type
Standard adhesive
Media Sizes
Roll (2.4 cm x 8 m)
Printing Technology
Thermal transfer
Media Colour
Black on red
Included Qty
1 cassette(s)
Colour Category
Red
Compatible with
Brother PT-D600 , Brother P-Touch PT-1400, PT-1500pc, PT-1600, PT-1650, PT-1900, PT-1910, PT-1950, PT-1950VP, PT-1960, PT-2110, PT-2200, PT-2210, PT-2300, PT-2310, PT-2400, PT-2400E, PT-2400ECC, PT-2410, PT-2420PC, PT-2430PC, PT-2480, PT-2500, PT-2500C, PT-2500PC, PT-2600, PT-2610, PT-2700, PT-2700VP, PT-2710, PT-2730, PT-2730VP, PT-330, PT-350, PT-350P, PT-3600, PT-520, PT-530, PT-540, PT-540C, PT-550, PT-550A, PT-580C, PT-7500VP, PT-7600VP, PT-9200, PT-9200DX, PT-9200PC, PT-9400, PT-9500, PT-9500pc, PT-9600, PT-9700PC, PT-9800PCN, PT-D600, PT-D600VP, PT-D800W, PT-E500, PT-E500VP, PT-E550W, PT-E550WS, PT-E550WSP, PT-E550WVP, PT-E800W, PT-H500, PT-H500LI, PT-P700, PT-P750TDI, PT-P750W, PT-P750WSP, PT-P900, PT-P900W, PT-P950NW , Brother P-Touch EDGE PT-P750WVP , Brother P-Touch R RL-700S
Brand: Brother
