The PT-D800W is a robust, standalone machine with battery option, so it can be used on-the-move, right where it's needed. It is lightweight, yet durable, with a secure carry handle for immediate portability and an inbuilt storage area for label tapes and included AC adapter. Its PC-style keyboard with integrated backlit display can be locked in place on the top of the device when being carried, then conveniently placed in front of the machine when in-use.
- Create durable labels up to 36mm in width
- High speed and high resolution printing
- Professional keyboard with integrated graphic backlit LCD smartphones
- Many built-in label templates for easy label creation
- Wi-Fi connectivity to print labels from tablets and smartphones
- Advanced cutter with easy label peel function
- Brother P-Touch PT-D800W - label printer - B/W - thermal transfer
- Printer Type
- Label printer - thermal transfer - B/W
- 3.4 kg
- Max Media Size
- Roll (3.6cm)
- Max Media Size (Custom)
- 36 mm
- Print Speed
- Up to 60 mm/sec
- Max Resolution (B&W)
- 720 x 360 dpi
- Interface
- Wi-Fi(n), USB 2.0
- Media Type
- Laminated tape
- Compatible Tapes
- TZe tape, HSe tape, FLe label
- Fonts
- 14 fonts
- Character Sizes
- 9 points, 6 points, 36 points, 24 points, 18 points, 12 points, 10 points, 14 points, 20 points, 28 points, 7 points, 11 points, 5 points, 56 points, 72 points, 48 points, 16 points, 8 points, 64 points, 40 points, 4 points, 22 points, 32 points, 80 points, 88 points, 90 points
- Styles & Effects
- Bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror, underline, italic solid, shadow light, surround, invert
- Printer Features
- Auto Power Off
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
- 33.7 cm x 18.8 cm x 17.3 cm
- Printer Type
- Label printer - thermal transfer - monochrome
Printer
- Print Speed
- Up to 60 mm/sec
- Interface
- Wi-Fi(n), USB 2.0
- 720 x 360 dpi
- Fonts
- 14 fonts
- Character Sizes
- Styles & Effects
- Printer Features
- Auto Power Off
Media Handling
- Media Type
- Laminated tape
- Compatible Tapes
- Max Media Size
- Roll (3.6cm)
- 36 mm
- Media Sizes
- Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm), Roll (0.35 cm), Roll (0.58 cm), Roll (2.36 cm), Roll (1.77 cm), Roll (1.17 cm), Roll (0.88 cm), 21 x 45 mm
- Media Feeders
- 1 x manual - 1 roll - Roll (3.6cm)
- Connections
- 1 x USB 2.0
- Cables Included
- 1 x USB cable
- Media Included
- 1 36 mm x 8 m black on white TZe tape
- Power Device
- Power adapter - external
- OS Required
- 10 °C
- 35 °C
- 20 - 80%
- 33.7 cm
- 18.8 cm
- 17.3 cm
- 3.4 kg
Ink (22)
Brother TZES221 Black on White 9mm | In Stock | £10.11 |
Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) | In Stock | £9.89 |
Brother TZE-651 24MM BLACK ON YELLOW | In Stock | £16.21 |
Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) | In Stock | £10.77 |
Brother TZES651 24mm Black on Yellow | In Stock | £14.54 |
Brother Laminated Tape 12mm Blk on Yel | In Stock | £9.67 |
Brother Tape Black on Yellow 6mm | In Stock | £7.78 |
Brother TZE-335 LAMINATED TAPE 12MM 8M | In Stock | £11.59 |
Brother Tape Black on Yellow 12mm | In Stock | £11.86 |
Brother Black On Clear Labelling Tape 12mm | In Stock | £8.73 |
Brother 12mm Black on White Tape | In Stock | £11.86 |
Brother Tape Black on Clear 9mm | In Stock | £7.78 |
Brother 12mm Matt Black on Red Laminated Tape | In Stock | £10.24 |
Brother P-touch (36mm x 8m) Black On Blue Labelling Tape | In Stock | £17.31 |
Brother TZe 661 Laminated Tape - 1 Roll | In Stock | £16.06 |
Brother TZESE4 Black on White 18MM Security Tape | In Stock | £24.49 |
Brother 12mm Blue on White Tape | In Stock | £10.24 |
Brother TZeN241 Non-Laminated Tape - 1 roll | In Stock | £9.87 |
Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape | In Stock | £7.54 |
Brother TZE621 9MM GLOSS Black on Yellow Tape | In Stock | £8.73 |
Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE | In Stock | £17.33 |
Brother TZEFX-231 Black On White Flexi Tape | In Stock | £11.86 |
Other bundles (1)
Brother TZe 231 - laminated adhesive tape - 1 roll(s) | In Stock | £9.61 |
