Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight.
P-touch TZ label tested to the extreme
Extensive testing has been performed to ensure that P-touch TZ label is incredibly durable under all kinds of conditions. It holds up extraordinarily well - and stays crisp, legible and affixed - even when subjected to abrasion, extreme temperature, industrial chemicals and sunlight. -
Abrasion resistant P-touch TZ label
Brother's patented tape technology ensures that Brother P-touch laminated label can withstand even heavy abrasion. -
Temperature resistant P-touch TZ label
Whether you want to use the label in freezing conditions or extremely warm environments, Brother P-touch laminated label has been designed to last. -
Fade resistant P-touch TZ label
Wherever you use P-touch laminated label, it will stay as clear and legible as the day it was applied. -
Water and chemical resistant P-touch TZ label
Testing TZ label 'to the extreme' has found it to be waterproof and resistant to chemical spill.
 - Brother TZe-621 - laminated tape - 1 cassette(s) - Roll (0.9 cm x 8 m)
- Product Type
 - Laminated tape
- Media Size
- Printing Technology
 - Direct thermal
- Media Colour
 - Black on yellow
- Included Qty
 - 1 cassette(s)
- Compatible with
 - Brother PT-D210, D600, H110, H200; P-Touch GL-H100, H105, PT-1005, 1010, 1290, 18, 1880, 3600, D200, D210, D400, D450, D600, D800, E110, E310, E500, E550, E800, H100, H101, H107, H110, H200, H500, P300, P700, P750, P900, P950; P-Touch Cube Plus PT-P710; P-Touch Cube Pro PT-P910; P-Touch EDGE PT-P750
- Dimensions (WxDxH) / Weight
 - 2 cm x 9 cm x 7 cm / 30 g
- Shipping Width
 - 7 cm
- Shipping Depth
 - 1.7 cm
- Shipping Height
 - 15.5 cm
- Shipping Weight
 - 49 g
Media
- Media Type
 - Laminated tape
- Media Sizes
 - Direct thermal
- Media Colour
 - Black on yellow
- Included Qty
 - 1 cassette(s)
- Colour Category
 - Yellow
- Compatible with
 - Brother PT-D210, PT-D600, PT-H110, PT-H200BP , Brother P-Touch GL-H100, GL-H105, GL-H105VP, PT-1000, PT-1000BTS, PT-1005, PT-1005BTS, PT-1005F, PT-1005FB, PT-1010, PT-1010B, PT-1010L, PT-1010NB, PT-1010NB Name Badge Kit, PT-1010R1, PT-1080, PT-1080BTS, PT-1080SBTS, PT-1090, PT-1090BK, PT-1100SB, PT-1100SBVP, PT-1100ST, PT-1130, PT-1150, PT-1150DX, PT-1160, PT-1170, PT-1170S, PT-1180, PT-1180HK, PT-1190, PT-11Q, PT-1230PC, PT-1250CC, PT-1250CCVP, PT-1250J, PT-1250LB, PT-1250S, PT-1250VP, PT-1250VPS, PT-1260VP, PT-1280, PT-1280BTS, PT-1280CB, PT-1280DT, PT-1280DT (50TH Year Anniversary Model), PT-1280SR, PT-1280VP, PT-1280VPS, PT-1290, PT-1290DT, PT-1290SBVP, PT-1290VP, PT-1400, PT-1600, PT-1650, PT-1760, PT-1800 PLUS, PT-1800ECC, PT-1830, PT-1830SC, PT-1830VP, PT-1850, PT-1850CC, PT-1850VP, PT-1880, PT-1880CT, PT-18R, PT-18RKT, PT-18RZ, PT-1900, PT-1910, PT-1950, PT-1950VP, PT-1960, PT-2030, PT-2030AD, PT-2030VP, PT-210, PT-2100, PT-2100VP, PT-2110, PT-2400ECC, PT-2420, PT-2430PC, PT-2450, PT-2450CC, PT-2450DX, PT-2460, PT-2470, PT-2480, PT-2600, PT-2610, PT-2700, PT-2700VP, PT-2710, PT-2730, PT-2730VP, PT-3600, PT-550A, PT-7100, PT-7100VP, PT-7500VP, PT-7600VP, PT-900, PT-900BTS, PT-900F, PT-9500, PT-9600, PT-9700PC, PT-9800PCN, PT-D200, PT-D200BW, PT-D200BWVP, PT-D200KT, PT-D200VP, PT-D210, PT-D210VP, PT-D400, PT-D400AD, PT-D400VP, PT-D450, PT-D450VP, PT-D600, PT-D600VP, PT-D800W, PT-E100, PT-E100VP, PT-E110, PT-E110VP, PT-E300, PT-E300VP, PT-E310BTVP, PT-E500, PT-E500VP, PT-E550W, PT-E550WS, PT-E550WSP, PT-E550WVP, PT-E800W, PT-GL-100, PT-GL-200, PT-GL-200VP, PT-H100, PT-H100LB, PT-H100R, PT-H101, PT-H101TB, PT-H105, PT-H107, PT-H107B, PT-H110, PT-H110LB, PT-H200, PT-H300, PT-H300LI, PT-H500, PT-H500LI, PT-H75, PT-H75S, PT-P300BT, PT-P700, PT-P750TDI, PT-P750W, PT-P750WSP, PT-P900, PT-P900W, PT-P950NW , Brother P-Touch Cube Plus PT-P710BT , Brother P-Touch Cube Pro PT-P910BT , Brother P-Touch EDGE PT-P750WVP
