Brother PT-D800W Mono Label Printer
Quicklinx: CKPWWS00 Mfr#: PT-D800WZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: Wireless
Technology: Thermal transfer
  • Windows 8 (32/64 bits)
£252.26 ex VAT
£302.71 inc VAT
The PT-D800W is a robust, standalone machine with battery option, so it can be used on-the-move, right where it's needed. It is lightweight, yet durable, with a secure carry handle for immediate portability and an inbuilt storage area for label tapes and included AC adapter. Its PC-style keyboard with integrated backlit display can be locked in place on the top of the device when being carried, then conveniently placed in front of the machine when in-use.
  • Create durable labels up to 36mm in width
  • High speed and high resolution printing
  • Professional keyboard with integrated graphic backlit LCD smartphones
  • Many built-in label templates for easy label creation
  • Wi-Fi connectivity to print labels from tablets and smartphones
  • Advanced cutter with easy label peel function
Brother P-Touch PT-D800W - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
3.4 kg
Max Media Size
Roll (3.6cm)
Max Media Size (Custom)
36 mm
Print Speed
Up to 60 mm/sec
Max Resolution (B&W)
720 x 360 dpi
Wi-Fi(n), USB 2.0
Media Type
Laminated tape
Compatible Tapes
TZe tape, HSe tape, FLe label
Fonts
14 fonts
Character Sizes
9 points, 6 points, 36 points, 24 points, 18 points, 12 points, 10 points, 14 points, 20 points, 28 points, 7 points, 11 points, 5 points, 56 points, 72 points, 48 points, 16 points, 8 points, 64 points, 40 points, 4 points, 22 points, 32 points, 80 points, 88 points, 90 points
Styles & Effects
Bold, italic outline, italic shadow, normal, vertical, outline, shadow, italic, Mirror, underline, italic solid, shadow light, surround, invert
Printer Features
Auto Power Off
Linux, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2, Apple MacOS X 10.9.x, Apple MacOS X 10.10.x, Windows 10 (32/64 bits), Apple MacOS X 10.11.x
33.7 cm x 18.8 cm x 17.3 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 60 mm/sec
Wi-Fi(n), USB 2.0
720 x 360 dpi
Fonts
14 fonts
Character Sizes
Styles & Effects
Printer Features
Auto Power Off
Media Handling
Media Type
Laminated tape
Compatible Tapes
Max Media Size
Roll (3.6cm)
36 mm
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (3.6cm), Roll (0.35 cm), Roll (0.58 cm), Roll (2.36 cm), Roll (1.77 cm), Roll (1.17 cm), Roll (0.88 cm), 21 x 45 mm
Media Feeders
1 x manual - 1 roll - Roll (3.6cm)
1 x USB 2.0
1 x USB cable
Media Included
1 36 mm x 8 m black on white TZe tape
Power adapter - external
10 °C
35 °C
20 - 80%
33.7 cm
18.8 cm
17.3 cm
3.4 kg
Ink (22)
CKPW Brother TZES221 Black on White 9mm In Stock £8.47
CKPW Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.80
CKPW Brother TZE-651 24MM BLACK ON YELLOW In Stock £15.66
CKPW Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £10.50
CKPW Brother TZES651 24mm Black on Yellow In Stock £14.17
CKPW Brother Laminated Tape 12mm Blk on Yel In Stock £9.58
CKPW Brother Tape Black on Yellow 6mm In Stock £7.70
CKPW Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.49
CKPW Brother Tape Black on Yellow 12mm In Stock £11.74
CKPW Brother Black On Clear Labelling Tape 12mm In Stock £8.66
CKPW Brother 12mm Black on White Tape In Stock £11.94
CKPW Brother Tape Black on Clear 9mm In Stock £7.70
CKPW Brother 12mm Matt Black on Red Laminated Tape In Stock £10.14
CKPW Brother P-touch (36mm x 8m) Black On Blue Labelling Tape In Stock £17.14
CKPW Brother TZe 661 Laminated Tape - 1 Roll In Stock £15.66
CKPW Brother TZESE4 Black on White 18MM Security Tape In Stock £24.61
CKPW Brother 12mm Blue on White Tape In Stock £10.14
CKPW Brother TZeN241 Non-Laminated Tape - 1 roll In Stock £9.78
CKPW Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.51
CKPW Brother TZE621 9MM GLOSS Black on Yellow Tape In Stock £8.66
CKPW Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE In Stock £16.10
CKPW Brother TZEFX-231 Black On White Flexi Tape In Stock £11.74
Other bundles (1)
CKPW Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.58
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (3.6cm)
Brand: Brother
