Brother P-Touch PT-P700 Mono Labelling Machine
Quicklinx: 9K2PWS00 Mfr#: PTP700ZU1
Type: Printer
Functionality: Printer
Output Type: Monochrome
Wireless Capability: [N/A]
Technology: Thermal transfer
£66.63 ex VAT
£79.95 inc VAT
With the PT-P700, clear, professional-looking labelling on files, archives, cupboards, shelves, data backup discs and more couldn't be simpler. Just plug direct into your PC or Mac via USB, and create designs using your existing fonts, images, graphics and frames. Features barcode printing and a wide range of downloadable templates available from the cloud, while labels are available in different colours and up to 24mm width.
And with up to 30mm per second print speed, the PT-P700 won't keep you waiting.
Brother P-Touch PT-P700 - label printer - B/W - thermal transfer
Printer Type
Label printer - thermal transfer - B/W
710 g
Max Media Size
Roll (2.4 cm)
Print Speed
Up to 30 mm/sec
Max Resolution (B&W)
180 dpi
Cutter
USB 2.0
Barcodes
Code 39, UCC/EAN-128, GS1 DataBar, QR code, MaxiCode, Aztec code, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Postnet, PDF417, Data Matrix, ITF, Micro QR code, GS1 DataBar Composites
Media Type
Laminated tape
Compatible Tapes
TZe tape
Character Sizes
72 points
Styles & Effects
Bold, normal, vertical, outline, shadow, italic, Mirror, underline, rotated text, frame, shadow light, surround, strikethrough
7 line printing
Required 6 x AA type
Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Apple MacOS X 10.8.x
7.8 cm x 15.2 cm x 14.3 cm
Printer Type
Label printer - thermal transfer - monochrome
Printer
Print Speed
Up to 30 mm/sec
USB 2.0
180 dpi
Character Sizes
72 points
Styles & Effects
7 line printing
Cutter
Barcodes
Media Handling
Media Type
Laminated tape
Compatible Tapes
TZe tape
Max Media Size
Roll (2.4 cm)
Media Sizes
Roll (2.4 cm), Roll (0.6 cm), Roll (1.8 cm), Roll (1.2 cm), Roll (0.9 cm), Roll (0.35 cm)
Max Printing Width
18.1 mm
Media Feeders
1 x manual - 1 roll - Roll (2.4 cm)
1 x USB 2.0 - 4 pin mini-USB Type B
Media Included
1 24 mm x 4 m black on white TZe laminated tape cassette
AA type
Required Qty
6
Software Included
Brother P-touch Editor V5.1
7.8 cm
15.2 cm
14.3 cm
710 g
Ink (17)
9K2P Brother TZES221 Black on White 9mm In Stock £10.44
9K2P Brother TZe-S211 - laminated tape - 1 cassette(s) - Roll (0.6 cm x 8 m) In Stock £9.59
9K2P Brother TZE-651 24MM BLACK ON YELLOW In Stock £16.80
9K2P Brother TZe-241 - laminated tape - 1 cassette(s) - Roll (1.8 cm x 8 m) In Stock £11.23
9K2P Brother TZES651 24mm Black on Yellow In Stock £15.22
9K2P Brother Laminated Tape 12mm Blk on Yel In Stock £9.38
9K2P Brother Tape Black on Yellow 6mm In Stock £7.52
9K2P Brother TZE-335 LAMINATED TAPE 12MM 8M In Stock £11.20
9K2P Brother Tape Black on Yellow 12mm In Stock £11.47
9K2P Brother Black On Clear Labelling Tape 12mm In Stock £8.48
9K2P Brother 12mm Black on White Tape In Stock £11.49
9K2P Brother Tape Black on Clear 9mm In Stock £7.58
9K2P Brother 12mm Matt Black on Red Laminated Tape In Stock £9.93
9K2P Brother 12mm Blue on White Tape In Stock £9.93
9K2P Brother P-touch TZe-211 (6mm x 8m) Black On White Label Tape In Stock £7.81
9K2P Brother BRO 24MM GLOSS TZ BLACK ON RED TAPE In Stock £16.80
9K2P Brother TZEFX-231 Black On White Flexi Tape In Stock £11.49
Other bundles (1)
9K2P Brother TZe 231 - laminated adhesive tape - 1 roll(s) In Stock £9.38
Type: Printer
Max Print Speed: [N/A]
Max Paper Size: Roll (2.4 cm)
Brand: Brother
