- Print/Scan/Copy/Fax
- Up to 27ppm Colour Print
- Up to 35ppm Mono Print
- Up to 6 Seconds First page
- USB,Network & Wireless
- Automatic Double Sided Printing
- Up to 1,200 x 4,800dpi Print
- 250 Sheet Input Tray
- 512MB RAM
- Windows & Mac Compatible
- 100 Sheet (A3) or 5 Sheet of other media Multi Purpose Tray
Efficient connectivity
With a wide range of connectivity options including AirPrint, NFC, USB 2.0, and Wi-Fi(n), the Brother MFC-J6935DW ensures seamless integration into any workspace. Mobile printing capabilities with Apple AirPrint and Google Cloud Print support make it easy to print from smartphones and tablets. -
High-quality printing and copying
Achieve professional-quality prints with max resolutions up to 4800 x 1200 DPI for both black and color prints. Automatic duplexing in both printing and copying offers convenience and efficiency, supporting media sizes up to A3/Ledger. -
Versatile media handling
Designed to meet the demands of high-volume environments, the printer features a robust 600-sheet standard media capacity, a 100-sheet bypass feeder, and supports a wide range of media types including envelopes, photo paper, and coated paper. -
Advanced scanning capabilities
The scanner supports automatic duplexing with a color depth of 24-bit and an interpolated resolution of up to 19200 x 19200 DPI, making it ideal for digitizing high-quality documents and images. -
Eco-friendly and cost-effective
ENERGY STAR certified, the Brother MFC-J6935DW is designed for efficiency with a power consumption of just 29 W during operation and 1.7 W in sleep mode, reducing environmental impact and operational costs.
- Brother MFC-J6935DW - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Localisation
- United Kingdom
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2000 pages
- Max Copying Speed
- Up to 12 ppm (mono) / up to 9 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Up to 22 ppm (mono) / up to 20 ppm (colour)
- Max Printing Resolution
- Up to 4800 x 1200 dpi (mono) / up to 4800 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 1200 x 2400 dpi
- Display
- 3.7"
- Original Size
- A3/Ledger (297 x 432 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 88.9 x 127 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
- Media Type
- Envelopes, plain paper, recycled paper, photo paper, coated paper, glossy paper
- Standard Media Capacity
- 600 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), NFC, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, save to USB flash drive, scan to e-mail, scan to network, scan to FTP, scan to OCR
- Power
- AC 230 V (50/60Hz)
- 57.5 cm x 47.7 cm x 37.45 cm
- 23.7 kg
- Environmental Standards
- ENERGY STAR Qualified
- Fax Type
- Plain paper
- Ink-jet - colour
- 30000 pages
- 250 - 2000 pages
- Display Diagonal Size
- 3.7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Localisation
- United Kingdom
- Standard Memory
- 512 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, 4 on 1, ID Card Copy
Printing
- Nozzle Configuration
- 420 nozzles (black), 3 x 420 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 cartridges (1 each: cyan, magenta, yellow, black)
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Printer Drivers / Emulations
- PCL 6, BR-Script 3, PDF 1.7, XPS
- First Print Out Time B/W
- 6 sec
- First Print Out Time Colour
- 6 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Fax Resolutions
- Reception Memory Capacity
- Up to 200 pages
- Transmission Memory Capacity
- Up to 200 pages
- PC Faxing
Fax Machine Features
- One-Touch Dialing
- 6 station(s)
- Speed Dialing
- 200 station(s)
- Caller ID
- Broadcast Transmission
- 250 stations
- Group dialling, Distinctive Ring
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 88.9 x 127 mm
- Max Media Size
- A3/Ledger
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), 100 x 150 mm, 130 x 180 mm, Folio (216 x 330 mm), 90 x 130 mm, 130 x 200 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 600 sheets
- 100 sheets
- 100 sheets
- 2 x input tray - 250 sheets size: 88.9 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , Bypass tray - 100 sheets size: 88.9 x 127 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 220 g/m² , ADF - 50 sheets size: 105 x 148 mm - A3/Ledger (297 x 432 mm) weight: 64 g/m² - 120 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 22 ipm - B/W (ISO/IEC 24734) , Printing: up to 20 ipm - colour (ISO/IEC 24734) , Copying: up to 12 ipm - B/W (ISO/IEC 24735) , Copying: up to 9 ipm - colour (ISO/IEC 24735) , Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Scanning: up to 18 ipm (A4) - B/W , Scanning: up to 18 ipm (A4) - colour , Scanning: up to 11 ipm (A3) - B/W , Scanning: up to 11 ipm (A3) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 1 x USB 2.0 host - 4 pin USB Type A , 1 x LAN - RJ-45
- WEP, WPA-PSK, WPA2-PSK, WPS, ARP, Wi-Fi Direct
- Operating System Support
- Linux, MS Windows Server 2008 R2 x64 Edition, MS Windows Server 2012 x64 Edition, Android, iOS, Apple Mac OS X 10.9, MS Windows Server 2008 (32/64-bits), MS Windows Server 2012 R2 x64 Edition, MS Windows Vista (32/64 bits), MS Windows 7 (32/64 bits), Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows Phone, Windows 10 (32/64-bits), Apple Mac OS X 10.11, macOS 10.12
- Voltage Required
- 29 Watt
- Power Consumption Standby
- 6.5 Watt
- Power Consumption Sleep
- 1.7 Watt
- Included Accessories
- Phone cable
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- 57.5 cm
- 47.7 cm
- 37.45 cm
- 23.7 kg
- Shipping Width
- 68.1 cm
- Shipping Depth
- 56.8 cm
- Shipping Height
- 50 cm
- Shipping Weight
- 28.4 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
