We do so much via mobile device these days that it's good to know there's a 600dpi scanner that's specifically designed to complement smartphones and tablets.
The rechargeable DS-820W syncs whatever you scan to your chosen mobile device and also offers a 4GB SD card and built-in wireless connectivity. Compatible with Windows and Mac, the DS-820W's professional software bundle also helps you manage and manipulate all the scanned data in a whole host of ways.
In short, this flexible and truly portable scanner enables you to work the way that suits you best.
or
here.
Fast scan speeds
Up to 8 pages per minute in both color and black/white. -
Wi-Fi transfer scanned documents
Wirelessly send scanned documents to your computer or mobile device. -
Versatile media handling
Easily scans documents, photos, receipts, business and plastic cards, and more. -
High-precision scanning
Up to 600 x 600 dpi optical resolution.
- Brother DSmobile 820W - sheetfed scanner - portable - USB 2.0, Wi-Fi(n)
- Sheetfed scanner - portable
- Interface Type
- USB 2.0, Wi-Fi(n)
- Scanning Sensor Type
- Contact Image Sensor (CIS)
- Additional Functions
- Email, scan to network share, scan to server, scan to flash card
- Max Supported Document Size
- 215.9 x 812.8 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 24-bit (16.7 million colours)
- Grayscale / Color Depth (External)
- 16-bit (64K grey levels) / 48-bit colour
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Size
- 215.9 mm x 812.8 mm
- Supported Document Type
- Plain paper, plastic card
- Document Feeder Type
- Manual
- Battery
- 1 x Lithium Ion
- System Requirements
- Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x, Apple MacOS X 10.8.x
- 30.8 cm x 5.25 cm x 4.07 cm
- 440 g
- 1-year warranty
- Interface Type
- USB 2.0, Wi-Fi(n)
- 215.9 x 812.8 mm
Scanner
- Input Type
- Grayscale Depth
- Grayscale Depth (External)
- Colour Depth
- 24-bit (16.7 million colours)
- Colour Depth (External)
- 48-bit colour
- 600 dpi x 600 dpi
- Scanner Speed Details
- 7.5 ppm - black & white - A4 - 300 dpi , 8 ppm - black & white - Letter - 300 dpi , 4.3 ppm - black & white - Letter - 400 dpi , 4 ppm - black & white - A4 - 400 dpi , 8 ppm - colour - Letter - 300 dpi , 7.5 ppm - colour - A4 - 300 dpi , 4.3 ppm - colour - Letter - 400 dpi , 4 ppm - colour - A4 - 400 dpi
- Scanner Features
- Powered by USB port, built-in LCD screen
- TWAIN
Media Handling
- Max Document Size
- Manual
- Supported Flash Memory Cards
- SD Memory Card
- Interfaces Details
- USB 2.0 - Type B
- Included Accessories
- Carrying case, cleaning cloth, calibration paper, 4 GB SD Memory Card, carrier sheet
- Cables Included
- 1 x micro-USB cable
- Battery Installed
- 1 x Lithium Ion
- Run Time (Up To)
- 450 pages
- Software Included
- Drivers & Utilities, Presto! BizCard 6, Nuance PaperPort 12 SE, Avision Button Manager 2, Presto! PageManager 9 for Mac, DSmobileCapture
- OS Required
- 30.8 cm
- 5.25 cm
- 4.07 cm
- 440 g
- Shipping Width
- 35.4 cm
- Shipping Depth
- 25.4 cm
- Shipping Height
- 7 cm
- Limited warranty - 1 year
- 5 °C
- 35 °C
- 15 - 85%
- Sound Emission
- 50 dBA
