Brother DS-620 A4 Colour USB Mobile Scanner
Quicklinx: 9K2GWS00 Mfr#: DS620Z1
The DS-620 can help you simplify how you work with paper documents – so that even when things get complicated, you'll still be able to keep your cool.
The lightweight DS-620 scans documents up to A4 as well as items like plastic ID cards and receipts. Easily powered via USB port and both Windows and Mac compatible, the DS-620 scans a page in just 8 seconds at 600dpi. And the professional software bundle supplied as standard means you can manage, edit and share it all simply.
  • Fast scan speeds
    Up to 8 pages per minute in both color and black/white.
  • High-precision scanning
    Up to 600 x 600 dpi optical resolution.
  • Versatile media handling
    Easily scans documents, photos, receipts, business and plastic I.D. cards, and more.
Brother DSmobile 620 - sheetfed scanner - portable - USB 2.0
Sheetfed scanner - portable
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Additional Functions
Email, scan to network share
Max Supported Document Size
215.9 x 812.8 mm
Input Type
Grayscale / Color Depth
16-bit (64k colours) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 colours) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Size
215.9 mm x 812.8 mm
Supported Document Type
Plain paper, business card, plastic card, photo
Document Feeder Type
Manual
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.8.x
29.05 cm x 5.25 cm x 3.67 cm
400 g
1-year warranty
Interface Type
USB 2.0
215.9 x 812.8 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
8-bit (256 colours)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Scanner Speed Details
8 ppm - black & white - Letter - 300 dpi , 7.5 ppm - black & white - A4 - 300 dpi , 4.3 ppm - black & white - Letter - 400 dpi , 4 ppm - black & white - A4 - 400 dpi , 8 ppm - colour - Letter - 300 dpi , 7.5 ppm - colour - A4 - 300 dpi , 4.3 ppm - colour - Letter - 400 dpi , 4 ppm - colour - A4 - 400 dpi
Scanner Features
Powered by USB port
TWAIN
Media Handling
Max Document Size
215.9 mm x 812.8 mm
Manual
Interfaces Details
USB 2.0 - Type B
Carrying pouch, calibration card, cleaning cloth, carrier sheet
1 x micro-USB cable
Power Consumption Operational (Standby)
2.5 Watt (1 Watt)
Software Included
DSmobileSCAN II, Presto! PageManager 9 SE
29.05 cm
5.25 cm
3.67 cm
400 g
Shipping Width
35.2 cm
Shipping Depth
23.2 cm
Shipping Height
6 cm
Limited warranty - 1 year
5 °C
35 °C
15 - 85%
Sound Emission
50 dB
