The Brocade FastIron CX series of switches provides new levels of performance, scalability, and flexibility required for today's enterprise campus networks. With advanced capabilities, these switches deliver performance and intelligence to the network edge in a flexible 1U form factor that helps reduce infrastructure and administrative costs.
Utilizing built-in 16 Gbps stacking ports and Brocade IronStack technology, organizations can stack up to eight switches into a single logical switch with up to 384 ports. PoE models support the emerging Power over Ethernet Plus (PoE+) standard to deliver up to 30 watts of power to edge devices, enabling next-generation campus applications.
Built for next-generation campus convergence
FastIron CX switches can deliver both power and data across network connections, providing a single-cable solution for campus edge devices such as Voice over IP (VoIP) phones, video surveillance cameras, and wireless access points. The switches are compatible with industry-standard VoIP equipment as well as legacy IP phones. -
Increased flexibility and scalability
FastIron CX switches provide a wide range of flexibility and scalability advantages for dynamic and growing campus networks. -
Reduced power consumption
In today's rapidly growing business environments, organizations need to minimize power consumption throughout the entire IT infrastructure. FastIron CX switches are designed to intelligently manage power usage, extending "green" initiatives to the wiring closet. -
High reliability in a compact form factor
The modular design also has a removable fan assembly. These features provide another level of availability for the campus wiring closet in a compact form factor. -
Comprehensive enterprise-class security
FastIron CX switches utilize the Brocade IronWare operating system, providing a rich security suite for Layer 2 and Layer 3 services, Network Access Control (NAC), and Denial of Service (Dos) protection. -
Simplified, secure management based on open standards
FastIron CX switches provide simplified, standards-based management capabilities that help organizations reduce administrative time and effort while securing their networks.
- Brocade FastIron CX 648S-HPOE - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - L3 - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE) + 4 x shared SFP + 2 x XFP
- Power Over Ethernet (PoE)
- PoE
- MAC Address Table Size
- 32K entries
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, static IP routing, PIM-DM, IGMPv3, PIM-SSM, ECMP, policy-based routing (PBR), MLDv2, MLD
- Remote Management Protocol
- SNMP 1, SNMP, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH-2
- Routing, Layer 3 switching, Layer 2 switching, DHCP support, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, manageable, stackable, WRR queuing, MAC address filtering, LFS, MRP support, sFlow, Brocade IronStack technology, PIM-SM snooping, RFN, VRRP support, VSRP support, FDP support, event log, DHCP snooping, TFTP support, ACL support, QoS, NAC, RADIUS support, SSH support, Jumbo Frames support, MLD snooping, DAI, temperature sensor, PoE+
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1v, IEEE 802.3ak, ANSI/TIA-1057, IEEE 802.1ab (LLDP), IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Optional
- 44 cm x 44 cm x 4.4 cm
- 4.5 kg
- Limited lifetime warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- 32K entries
- Max Units In A Stack
- 8
- Routing Protocol
- Encryption Algorithm
- AES
- Authentication Method
- RADIUS, TACACS, TACACS+, Secure Shell v.2 (SSH2), Extensible Authentication Protocol (EAP)
- 48 x 10Base-T/100Base-TX/1000Base-T - RJ-45 PoE , 1 x console - 9 pin D-Sub (DB-9) management , 1 x Ethernet - RJ-45 management , 2 x network stack device , 2 x XFP , 4 x SFP (mini-GBIC)
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 1
- Max Supported Qty
- 2
- Power Redundancy
- Optional
- Power Redundancy Scheme
- 1+1 (with optional power supply)
- Voltage Required
- Plug and Play, FCC Class A certified, CISPR 22 Class A, EN55022, VCCI Class A ITE, WEEE, RoHS
- 44 cm
- 44 cm
- 4.4 cm
- 4.5 kg
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 5 - 95%
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £13.89 |
