TRENDnet TPE-2840WS 28-Port Gigabit Web Smart PoE+ Switch
Quicklinx: B5FMWS00 Mfr#: TPE-2840WS
TRENDnet's 28-Port Gigabit Web Smart PoE+ Switch, model TPE-2840WS, offers 4 x Gigabit PoE+ ports (Ports 1-4 802.3at), 20 x Gigabit PoE ports (Ports 5-24 802.3af), 4 x SFP slots, and a PoE Power budget of 185 Watts. This IPv6 ready switch offers advanced traffic management, troubleshooting, access control, energy saving GREENnet, and monitoring features at a reduced cost.
Hardware Design
Provides 4 x Gigabit PoE+ ports (Ports 1-4 802.3at), 20 x Gigabit PoE ports (Ports 5-24 802.3af), 4 x SFP slots, a PoE Power budget of 185 Watts, and includes rackmount brackets.
Smart Fan
Smart fan saves energy by varying fan speed and use based on cooling needs.
IPv6 Ready
This switch supports IPv6 configuration and IPv6 neighbor discovery.
Traffic Management
A broad range of network configurations are supported by: 802.3ad link aggregation, Asymmetric VLAN, 802.1Q VLAN, Voice VLAN, Private VLAN, Bandwidth Controls, GVRP, IGMP v1-v3, 802.1p Class of Service (CoS), Spanning Tree (STP, RSTP, and MSTP), and QoS queue scheduling.
Troubleshooting
Real time traffic comparison charts, error group charts, and a convenient cable diagnostic test aid in rapid troubleshooting.
Access Controls
Features such as ACL, SSL, MAC/port filtering, Denial of Service controls, 802.1X, TACACS+, and RADIUS are compatible with layered network access controls.
Monitoring
RMON, SNMP, SNMP Trap, and Port Mirroring support administrator monitoring solutions.
  • Hardware design
    Provides 4 x Gigabit PoE+ ports, 20 x Gigabit PoE ports, 4 x SFP slots, a PoE Power budget of 185 watts, and includes rackmount brackets.
  • Smart fan
  • IPv6 ready
  • Traffic management
  • Troubleshooting
  • Access controls
    Features such as ACL, SSL, MAC/port filtering, Denial of Service controls, 802.1x, TACACS+, and RADIUS are compatible with layered network access controls.
TRENDnet TPE TPE-2840WS 28-Port Gigabit Web Smart PoE+ Switch - switch - 28 ports - Managed - rack-mountable - TAA Compliant
Switch - 28 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE+) + 20 x 10/100/1000 (PoE) + 4 x SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
185 W
Performance
Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 41.7 Mpps
MAC Address Table Size
16K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3, static IPv6 routing
Remote Management Protocol
SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
DHCP support, VLAN support, Weighted Round Robin (WRR) queuing, IPv6 support, GREENnet technology, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Virtual Cable Test (VCT) technology, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Quality of Service (QoS), RADIUS support, reset button, Management Information Base (MIB), Dynamic VLAN Support (GVRP), Class of Service (CoS), tagged VLAN, Loopback, Denial of Service (DoS), Duplicated Address Detection, per port bandwidth control, DiffServ Code Point (DSCP) support, PoE overcurrent protection, PoE circuit sorting protection, 3 fans
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
44 cm x 25 cm x 4.445 cm
3.8 kg
Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista / XP / 7 / 8 / 8.1
TAA Compliant
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
185 W
Performance
16K entries
Routing Protocol
Encryption Algorithm
TLS, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+
RAM
1 MB
Status Indicators
Power, PoE, link/activity, SFP
4 x 1000Base-T RJ-45 PoE+ , 20 x 1000Base-T RJ-45 PoE , 4 x SFP
Internal power supply
240.2 Watt
Rack Mounting Kit
Included
MTBF
257,362 hours
UL 60950, FCC, RoHS, WEEE
TAA Compliant
Software Included
Drivers & Utilities
44 cm
25 cm
4.445 cm
3.8 kg
Limited warranty - lifetime
-5 °C
50 °C
0 - 90% (non-condensing)
