PowerCart 16 promotes a robust all steel construction alongside an energy saving timer module that prevents energy wastage as well as protecting your building circuits.
Energy saving timer
The built-in power management system not only protects your laptops and prevents your building's circuits from being tripped, but it also features an energy-saving timer unit with 2 programmable timer options, which can be set to start charging over 2 separate time periods in one 24 hour cycle. The timer can also be set to charge your laptops during the evening or weekend to take advantage of off-peak energy supply hours, helping to reduce your electricity bills. -
Simultaneous data transfer
Updating a full set of laptops with the PowerCart 16 is simple. Featuring a built-in 19" rack for mounting a network switch, as well as an optional fan and network kit upgrade, which enables all laptops to be connected to the LAN and simultaneously updated even whilst charging. -
Easy to use, neat and tidy
PowerCart is quick and easy to set up with power pack shelves in the rear of the cart along with reduced length 2-pin and 3-pin power adaptor leads, which dispense with the laptop's own 3-pin plug and lead, reducing the amount of excess cable and eliminates cable clutter. -
Low maintenance
All the electronics are housed in an easily removable timer module. -
Robust all-steel construction
The robust all-steel construction provides a significant theft deterrent, while the separate lockable ICT technician door offers secure access to the power module to prevent unauthorized tampering.
- Bretford PowerCart L16H cart - for 16 notebooks
- Product Type
- Cart
- Integrated Devices
- Fan
- 102 cm x 55 cm x 98 cm
- Recommended Use
- 16 notebooks
- Material
- Steel
- 12 years warranty
- 102 cm
- 55 cm
- 98 cm
- Material
- Steel
AV Furniture
- Cart
- Recommended Use
- 16 notebooks
- Fan
- Cable Management
- Integrated cable management
- Locking casters, lockable, Electric Power Management (EPM)
- Limited warranty - 12 years , Limited warranty - power system - 2 years
