USB-C Multiport Adapter - HDMI & Mini DisplayPort Video - 100W PD Pass-Through - 4-Port USB Hub.
Maximum Resolution
The portable docking station connects your laptop to a 4K 60Hz HDMI or mini DisplayPort monitor (4096 x 2160p) to create a powerful workstation. Can be used with an mDp to DP video adapter to connect your DP monitor and can also connect to an ultrawide monitor. -
Connect Your Devices
The USB-C to USB 3.1 Gen 2 hub gives you one USB-C port and three USB-A ports to connect your legacy USB devices. -
Charge Your Laptop and Peripheral
With support for USB PD 3.0 (up to 100W), the USB Type-C multiport adapter lets you power and charge your laptop, and power your peripherals when connected to a USB-C power adapter. PD 3.0 features Fast Role Swap to prevent USB data disruption when you switch power sources (USB-C power adapter to bus power). The DKT31CMDPHPD is backed by a StarTech.com 3-year warranty and free lifetime technical support. Note:?To ensure full adapter functionality, your laptop's USB-C port must support USB Power Delivery.
- StarTech.com USB C Multiport Adapter, USB-C to HDMI or Mini DisplayPort 4K 60Hz, 100W Power Delivery Pass-Through, 4-Port 10Gbps USB Hub, USB Type-C Mini Dock, 12"/30cm Long Attached Cable - Works w/ Thunderbolt 3 (DKT31CMDPHPD) - docking station - USB-C / Thunderbolt 3 - HDMI, Mini DP
- Product Type
- Docking station
- Docking Interface
- Video Interfaces
- HDMI, Mini DP
- 84.3 g
- 3-year warranty
- Product Type
- Docking station
- 84.3 g
Video
- Max Resolution Details
- 4K - 60 Hz (DisplayPort 1.4 only) , 4K - 30 Hz (DisplayPort 1.2 only)
- 1 x display / video - HDMI - 19 pin HDMI Type A , 1 x display / video - Mini DisplayPort - Mini DisplayPort , 1 x USB-C 3.2 Gen 2 - 24 pin USB-C , 1 x USB-C 3.2 Gen 2 with Power Delivery (100 W) (power only) - 24 pin USB-C , 1 x USB 3.2 Gen 2 with Battery Charging 1.2 - 9 pin USB Type A , 2 x USB 3.2 Gen 2 - 9 pin USB Type A
- Cables Included
- 1 x USB-C cable - integrated - 30 cm
- 100W power delivery, DisplayPort Alt Mode
- DisplayPort 1.4, USB Power Delivery 3.0, FCC, RoHS
- OS Required
- Windows 8.1 / 10 / 11, Apple macOS 10.13 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Apple macOS 13.0, Google Chrome OS, Ubuntu 18.04, Ubuntu 20.04, Apple iPadOS, Android
- Limited warranty - 3 years
- Shipping Width
- 14 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 153 g
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter | In Stock | £9.00 |
StarTech.com 4m USB 2.0 C Cable w/ PD (5A) | In Stock | £15.43 |
StarTech.com 2m USB 3.0 C Cable w/ PD (3A) | In Stock | £14.59 |
StarTech.com 1m USB 3.1 C Cable w/ PD (5A) | In Stock | £25.86 |
StarTech.com 6ft Premium Certified HDMI 2.0 | In Stock | £12.98 |
