Bosch Smart Home Motion Detector
Quicklinx: GY94WS00 Mfr#: 8750000018
Bosch Smart Home Motion Detector keeps an eye on the inside of your home. Use it as part of the alarm system when you leave the house. It detects movements reliably and precisely, instantly sounds an alarm and warns you immediately via app if unwanted guests try to gain access to your living spaces. When you are at home, use your smart Motion Detector for automatic lighting control.
Smart motion detection
The Motion Detector's intelligent sensors prevent false alarms: The Bosch Smart Home Motion Detector recognizes human movement based on body heat and size, thus differentiating between humans and pets. As a result, the alarm is only triggered when it is really necessary.
Triggers alarm signal
When you leave the house, you can activate your Motion Detector as part of the alarm system. If an unusual movement is detected while activated, the smart Motion Detector reacts in two ways: It immediately sends you a notification via the app. At the same time, it triggers an alarm signal, for example by the siren of your Smoke Detector.
Automatic light control
When you are at home, simply switch off the alarm function - and use the Motion Detector for automatic lighting control. In combination with your Philips Hue lamps and/or the Smart Plug, the sensores of the indoor Motion Detector automatically switch on the lights you have selected when there is movement.
Integrated pet immunity for your pet
Your pets can still move around the house without any problems despite your smart Motion Sensor Alarm. Simply activate the integrated pet immunity function. This ensures that the Bosch Smart Home Motion Detector also recognizes movements by pets up to approx. 25 kg and ignores them.
Box contents
  • 1 motion detector
  • 1 lithium-ion long-life battery
  • Fixing materials for screw and adhesive mounting
  • 1 installation instructions
  • Has everything in view in case of an alarm and is hard to trick
    Thanks to its 90° front viewing angle and 12-meter range, the Bosch Smart Home Motion Detector also optimally captures large rooms. There is also no danger of uninvited guests crawling under the sensor of your intelligent Motion Detector. This is because the sneak-by guard prevents this trick. The demolition alarm also provides additional security: even if it is torn from the wall by a burglar, the Motion Detector still reacts with an alarm.
  • Smart sensors avoid false alarms
    The Bosch Smart Home Motion Detector differs from conventional motion detectors by the combination of different intelligent sensors. This enables it to distinguish between different types of movement more reliably. It recognizes people by their body heat and size using infrared and temperature sensors. Moreover, the smart motion sensores of the Detector intelligently filter out irrelevant movements caused by reflections or wind in trees and curtains, thus avoiding unnecessary false alarms.
  • Integrated pet immunity for your pet
  • Intelligent activation of your lamps
    As part of the Bosch Smart Home system, the Motion Detector automatically switches on the light when movement is detected. By the way, this doesn't only work with your Philips Hue lamps: simply connect all other lamps via the Smart Plug. The Motion Detector also takes daylight into account. By adjusting the light sensitivity, you decide when the lights turn on. With your Philips Hue lamps you can also dim the light. Manage your smart light control easily via the app.
Bosch Smart Home - motion sensor
Motion sensor
Power Source
Wireless
Frequency Band
2.4 Ghz
6 cm x 4.2 cm x 10.8 cm
Motion sensor
Power Source
Wireless
Max Range Open Space
50 m
Frequency Band
2.4 Ghz
Pet immunity up to 25 kg
Lithium
Battery Lifetime
5 years
IP20
6 cm
4.2 cm
10.8 cm
98 g
Shipping Width
9.2 cm
Shipping Depth
10.275 cm
Shipping Height
18.15 cm
50 °C
0 - 93%
