Brand
Bosch Eyes Outdoor Camera
Quicklinx: GY91WS00 Mfr#: F01U314889
Type: Outdoor Camera
Compatible With: Alexa
£233.33 ex VAT
£279.99 inc VAT
The outdoor camera from Bosch Smart Home protects your home while simultaneously providing an atmospheric exterior light.
Security and design right on your doorstep
With the smart Eyes Outdoor Camera, you have a live view of your home, driveway and garden at all times. In addition to reliable property surveillance, it offers atmospheric exterior lighting. Use the home security camera independently with the Bosch Smart Camera App or as part of the entire Bosch Smart Home System.
See what's going on - around the clock
The surveillance camera secures your property around the clock. As soon as it registers a movement, you will receive live images via push message directly to your smartphone.
Motion light and design light in one
The Eyes outdoor camera monitors your home and ensures your well-being at home with pleasant, dimmable mood light and integrated motion light.
No follow-up costs
Store 200 clips in a cloud for up to 30 days for free - and 25 favorites for an unlimited time. Of course the app and updates are also free.
Record relevant movements
The wireless Eyes Outdoor Camera checks twice before recording relevant movements as a video clip. Via its image sensor, it detects changes in the image and intelligently combines them with its motion sensor which can distinguish between movements of persons and objects based on body heat. Loud noises can also be used as a trigger for video recording. The masking function in the app also allows you to hide areas that you are not allowed to film.
Sharp vision in colour - day and night in Full-HD
Thanks to integrated lighting, the Eyes outdoor camera records Full-HD colour videos around the clock and notifies you directly via push notification on your smartphone. This way, you have a good view of your home even in the dark.
Easy, intuitive installation
Goodbye to installation work! The smart surveillance camera with motion sensores can be mounted anywhere where an exterior light can be installed. All you need is a 230 V power connection. Commissioning is done in a few minutes via app. For further help please watch our installation videos.
Independent use or smart connectivity
The choice is yours: The Eyes Outdoor Camera functions as a component in the entire Bosch Smart Home System - but also independently. For stand-alone use, all you need is the Bosch Smart Camera App, no Bosch Smart Home Controller. You would like to combine your outdoor camera with other Bosch Smart Home devices? Then connect them via the Bosch Smart Home Controller and the Bosch Smart Home App and benefit from additional functions.
Feel safe thanks to guaranteed data protection
Good to know: The data and video from your surveillance camera are protected from unauthorized access. The transmission of live streams and the storage of your videos are encrypted. The cloud server is located in Germany and is therefore subject to the highest security standards and the German Data Protection Act.
Box contents
  • 1 Eyes-Outdoor Camera
  • 1 Wall holders with mounting materials
  • 1 Installation guide
  • Security and design right on your doorstep
  • See what's going on - around the clock
  • Motion light and design light in one
  • Sharp vision in color - day and night in Full HD
    Thanks to integrated lighting, the Eyes outdoor camera records Full HD color videos around the clock and notifies you directly via push notification on your smartphone. This way, you have a good view of your home even in the dark.
  • Easy, intuitive installation
Bosch Smart Home Eyes-Outdoor Camera - network surveillance camera
Network surveillance camera - fixed - outdoor - waterproof
Audio
Yes: built-in speaker, two-way audio capability
Camera Mount Type
Wall mount
21 cm x 10 cm x 7 cm
Wireless
Camera
Colour - Day&Night
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Intelligent Assistant
Alexa
Voltage
AC 220-240 V
120° field of view, 10m illumination distance
Environmental Parameters (operating)
-20 °C - 50 °C
Audio Support
Camera Mount Type
Wall mount
Wireless
21 cm
10 cm
7 cm
Camera
Colour - Day&Night - fixed - outdoor - waterproof
Video Modes
1080p
RAM
4 GB
Network Interface
Wall mount kit
AC 220-240 V 4 Watt
Internet of Things (IoT)
Alexa
Shipping Width
27.15 cm
Shipping Depth
10.275 cm
Shipping Height
18.2 cm
Shipping Weight
750 g
-20 °C
50 °C
Brand: Bosch
Stock Status: In stock
