An affordable wireless 'N' modem/router that offers increased wireless coverage and faster wireless speeds with 2T x 2R technology (2 transmit/2 receive), as well as rock-solid, fast Internet access via your ADSL line, with download speeds up to 24 Mbps with ADSL2+, incorporating WPA2 encryption for optimum wireless security and a SOHO firewall and QoS. In addition an Easy Install CD provides a hassle-free set-up experience - ideal for the home user.
Features:
* High speed internet access with ADSL2/2+ Broadcom chipset integrated with 4-port Ethernet Switch
* Faster downloads, extra stability, good on long lines
* 300 Mbps Wireless AP with WPA / WPA2 support 'N'
* Easy set-up CD included
* Firewall Security with DoS Prevention and Packet Filtering, QoS
* Ideal for Home and SOHO Users
Optimal wireless speeds and coverage
Utilizing the benefits of Wireless N technology, BiPAC 7700N performs faster file transfers and farther coverage enabling greater wireless signals across your home. If the network requires wider coverage, the built-in Wireless Distribution System (WDS) repeater function allows users to expand the wireless network without the need for any external wires or cables. Upgrading your home network to Wireless N provides an excellent solution for experiencing better wireless performance while sharing a broadband Internet connection with multiple computers over a secure wireless network. -
Quality transmission enhances Internet experience
Quality of Service (QoS) gives full control over outgoing data traffic. Priority can be assigned by the router to ensure that important transmissions like gaming packets, VoIP calls or IPTV/streaming content passes through the router at lightning speed, even when there is heavy Internet traffic. The VLAN support is also capable of establishing reliable high-speed transmissions for wide bandwidth applications such as IPTV, VOD, or online gaming without consuming bandwidth. -
High-speed Internet access
The BiPAC 7700N is compliant with worldwide ADSL standards. The integrated Annex M standard supports ADSL2/2+ for higher uploads by doubling the upload data rate. The 4-port Ethernet switch incorporated into the BiPAC 7700N enables users to connect to multiple computers or wired-Ethernet devices easily and enjoy blistering LAN transmission for multimedia applications such as interactive gaming, IPTV video streaming and real-time audio.
- Billion BIPAC 7700N - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- PPPoE, AAL5, IPoA, OAM F4, OAM F5
- Remote Management Protocol
- SNMP 1, SNMP 2
- Firewall protection, switching, DMZ port, routing, DHCP support, NAT support, VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, packet filtering, dynamic DNS server, manageable, WDS support, QoS, WPS
- ANSI T1.413, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP
- 15 cm x 11 cm x 2.2 cm
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- SNMP 1, SNMP 2
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
Communications
- DSL modem
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.994.1 (G.hs), ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.992.5 Annex M, ITU G.992.3 Annex M
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2 dBi
- Power Device
- External power adapter
- 15 cm
- 11 cm
- 2.2 cm
- 0 °C
- 40 °C
- 20 - 95% (non-condensing)
