- Cable length 45cm
- Meets Intel v2.03 enhanced +12V
- 230V with rear on/off power down button
- Over-voltage and current protection +3.3V;+5V;+12V
- 100% Burn in and hipot tested; short circuit protection
- EMI Filter built in
- CE/ FCC/ UL approved
- ROHS Compliant
- +3.3V 24A; +5V 34A; +12V 38A; -12V 0.5A; +5VSB 2.0A
- Silent 120mm blue fan with low noise technology <20dBA
- Packaged in designer retail box
- Quiet fan with thermal control
- Black coated casing
- 24 pin; 4 Pin (12V); 1 x 6 pin PCI-e; 4 x Sata; 3 x 4 pin; 1 x FDD
