With the BL702A Flicker-free LED backlight panel, an ultra-high dynamic contrast ratio of 120,000:1, and BenQ's exclusive Senseye technology to offer you the best viewing quality at all times. The BenQ BL702A is designed with computer ergonomics in mind to add comfort and flexibility to your everyday work - boosting productivity and efficiency at the same time!
                Flicker-free backlight for visual pleasureThe BL702A is upgraded to eliminate flickering at all brightness levels, effectively reducing eye fatigue. The Flicker-free technology eliminates flickering at all brightness levels and effectively reducing eye fatigue. Conventional LCD screens flicks 200 times per second. Your eyes may not see flickers, but can certainly feel them. Free your eyes from flickers by switching to Flicker-free monitors and let your eyes do less work.
                Low blue light modeEvery monitor produces a strain of blue spectrum light that is one of the critical causes of eye damage, eye strain, headaches and sleeping disorders. BenQ's unique low blue light technology is designed to deal with the everyday problem of blue light exposure and allows a healthier time spent in front of your computer. Switch to one of the four preset low blue light modes from OSD hot key, and reward your eyes without having to lose the visual enjoyment.
                Senseye 3 visual solution to your everyday viewing needsExperience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and ECO - with the ECO mode especially design to save power and money.
                12M:1 DCR for depth and definitionThe BL702A comes with an ultra-high dynamic contrast ratio of 12M:1 to add color depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance.
- BenQ BL702A - BL Series - LED monitor - 17"
- LED-backlit LCD monitor - 17"
- Panel Type
- TN
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- Black
- Environmental Standards
- ENERGY STAR Qualified
- TUV, GS
- 2-year warranty
- Display Type
- Diagonal Size
- 17"
- Panel Type
- TN
- Native Resolution
- 1280 x 1024
- Pixel Pitch
- 0.264 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, contrast, H/V position, sharpness, colour temperature, phase
- Senseye 3 Technology
- Black
- VGA
Mechanical
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable
- TUV, GS
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- Dimensions & Weight Details
- - weight: 2.5 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 2 years - on-site
- 5 °C
- 40 °C
- 20 - 90% (non-condensing)
