The BL3290QT enhances the overall productivity as one USB-C cable and integrated USB-hub connects all. With impeccable details and quality, the BL3290QT comes with a design that boasts an elevated level of elegance at work.
- BenQ BL3290QT - BL Series - LED monitor - 31.5"
- LED-backlit LCD monitor - 31.5"
- Energy Class
- Class F
- Daisy Chaining
- USB PD 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440 at 75 Hz
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, USB-C
- Audio Input
- Microphone
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V
- Dimensions (WxDxH) - with stand (landscape orientation)
- 71.46 cm x 25.15 cm x 59.77 cm
- 10.1 kg
- Environmental Standards
- TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Bronze
- HDCP 1.4, TUV Rheinland Eyesafe 2.0 Display
- 2-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 31.5"
- Daisy Chaining
- USB Power Delivery
- 65 watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Per Inch
- 93
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- OSD Languages
- Hungarian, Czech, Chinese (traditional), Chinese (simplified), English, German, French, Italian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Arabic, Romanian, Japanese, Korean
- Advanced Motion Accelerator (AMA) technology, game mode, Flicker Free technology, M-book Mode, K Locker, Color Weakness Mode, Low Blue Light Plus technology, Movie Mode, Brightness Intelligence Technology, ePaper mode, Eye Reminder technology, coding mode
- 71.46 cm x 25.15 cm x 59.77 cm - with stand (landscape orientation)
- 10.1 kg
Audio Input
- Microphone
- Microphone Features
- Noise-cancelling
Audio
- Speakers - stereo
- Output Power / Channel
- 2 watt
- HDMI , DisplayPort 1.2 , USB-C upstream/DisplayPort Alt Mode with Power Delivery (DisplayPort Alt Mode, power up to 65W) , USB-C downstream (BC 1.2) , 3 x USB 3.2 Gen 1 (Type A) , Headphone jack , DisplayPort output (MST)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 40
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Ergonomic, internal power supply
- Cables Included
- 1 x HDMI cable - 1.5 m , 1 x USB-C cable - 1.5 m
- Backlight Life
- 30,000 hours
- MTBF
- 60,000 hour(s)
- Input Voltage
- AC 100-240 V
- Power Consumption SDR (On mode)
- 32 kWh/1000h
- Power Consumption (Typical)
- 25 watt
- Power Consumption (Max)
- 152 watt
- Power Consumption Sleep
- 0.5 watt
- 0.3 watt
- Dimensions & Weight Details
- With stand (landscape orientation, lowest position) - width: 71.46 cm - depth: 25.15 cm - height: 48.81 cm - weight: 10.1 kg , With stand (landscape orientation, highest position) - width: 71.46 cm - depth: 25.15 cm - height: 59.77 cm - weight: 10.1 kg , With stand (portrait orientation) - width: 42.87 cm - depth: 25.15 cm - height: 73.59 cm - weight: 10.1 kg , Without stand - width: 71.46 cm - depth: 6.26 cm - height: 42.87 cm - weight: 7.2 kg
- Shipping Weight
- 12.6 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 2 years
