BenQ GL2450HM 24" LED 1920x1080 VGA DVI HDMI Black Monitor with Speakers
Quicklinx: 8N8DWS00 Mfr#: GL2450HM
Whether you're catching up on the latest show on the Internet or viewing documents, the BenQ GL2450HM LED monitor is the perfect choice for you in style! Featuring a dynamic ratio of 12000000: 1, speakers, response time of 2 ms and DVI and HDMI connector, this 24" 16:9 LED monitor delivers you the audiovisual enjoyment.
  • Brilliant image quality
    LED backlighting offers significant advantages over the CCFL technology used in older LCD monitors. These advantages encompass not only performance metrics such as higher dynamic contrast, no light leakage and flicker-free, but also environmental factors, like a manufacturing process and disposal that produces fewer pollutants.
  • 12000000: 1 ultra high dynamic contrast for depth and definition
    The GL2450HM comes with an ultra-high dynamic contrast ratio of 12000000: 1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games.
  • Perfecting your audiovisual enjoyment with speakers
    Whether you're listening to music or watching your favorite film, simply turn on the speakers to experience the audiovisual fun!
  • HDMI multimedia interface
    The HDMI high-speed multimedia interface makes the monitor incredibly convenient to use - you can enjoy digital entertainment effortlessly even with additional multimedia equipment in the future.
  • Superior response time
    Enjoy high dynamic videos without ghosting or other artifacts with 2 ms GTG response time.
  • Senseye technology
    Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money.
  • Save energy to save up
    Energy-efficient LED panel provides greater power saving by 14.3% and with the help of eco mode, you can save up to 39.3%.
  • ENERGY STAR qualified
    The GL2450HM complies with the requirement of ENERGY STAR program for computer monitors. You can enjoy saving energy and money as well as keeping the Earth lookin' great!
BenQ GL2450HM - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
39 kWh
Power Consumption (On mode)
27 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 12000000:1 (dynamic)
Response Time
2 ms (gray-to-gray), 5 ms (tr - tf)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, DVI-D, VGA
Speakers
Integrated
Display Position Adjustments
Tilt
Voltage
AC 120/230 V
Glossy black
57.9 cm x 17.9 cm x 43.6 cm
4.1 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Display Type
Energy Class
Class B
39 kWh
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Advanced Motion Accelerator (AMA) technology, Senseye Human Vision Technology, Senseye 3 Technology
Glossy black
57.9 cm x 17.9 cm x 43.6 cm - with stand
4.1 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
2 Watt
DVI-D (HDCP) , HDMI , VGA
Mechanical
Tilt
Tilt Angle
-5/+15
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Power Supply
Internal
Input Voltage
AC 120/230 V
27 W
Power Consumption (Typical)
42 Watt
Power Consumption Stand by
0.3 Watt
On / Off Switch
No
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
