BenQ G2222HDL 21.5" 1920 x 1080 5MS DVI-D VGA Widescreen Full HD LED Monitor
Quicklinx: 7JTGWS00 Mfr#: 9H.L3RLN.IBE
BenQ invites you to embrace the ultimate Full HD visual enjoyment that's tailored to complement your personal lifestyle - a Full HD 16:9 LCD monitor made to fit your room and your budget perfectly. Here at BenQ, the personal Full HD visual entertainment is the one true luxury that everyone should be able to own. So, indulge yourself in the world of Full HD digital entertainment - whether it's playing your PS3 games or sharing with your loved ones the cherished moments caught by your HD camcorder! With the BenQ Full HD 16:9 LCD monitor, everything is looking great!
  • 5,000,000:1 DCR (Dynamic Contrast Ratio) offers you the finest details
    With a dynamic contrast ratio of 5,000,000:1 to give you splendid image details and clarity in darkened and complex motion pictures, everything becomes more vivid!
  • RoHS compliance
    BenQ do care about the living environment; all BenQ LCD monitors have RoHS certification (Restriction of the use of certain Hazardous Substances). The RoHS Directive stands for "the restriction of the use of certain hazardous substances in electrical and electronic equipment".
BenQ G2222HDL - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 5000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy black
51 cm x 17.5 cm x 39.3 cm
3.8 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Display Type
Diagonal Size
21.5"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
83 kHz
Video Bandwidth
205 MHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
LED backlight
Controls & Adjustments
Colour temperature
HDCP, Senseye Technology
Glossy black
3.8 kg
VGA , DVI-D
Mechanical
Tilt
Security lock slot (cable lock sold separately), wall mountable
1 x VGA cable
Security Slot Type
Kensington security slot
Power Supply
Internal
Power Consumption (Typical)
28 Watt
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
