Stable feedback technology prevents the harmful effects of flickering that strain the eyes. Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation.
Flicker-free
Stable feedback technology prevents the harmful effects of flickering that strain the eyes. -
Low Blue Light
Unique BenQ Low Blue Light Technology is designed to filter out harmful blue light, effectively diminishing eye fatigue and irritation. -
Height Adjustment Stand (HAS)
The HAS allows you to find the best viewing angles for personal work or screen sharing with an extensive range of monitor adjustments.
- BenQ BL2405PT - BL Series - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class A
- Energy Consumption per Year
- 32 kWh
- Power Consumption (On mode)
- 22 W
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 12000000:1 (dynamic)
- Response Time
- 2 ms (gray-to-gray), 5 ms (tr - tf)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V
- Black
- Dimensions (WxDxH) - without stand
- 57.9 cm x 6.3 cm x 35 cm
- 5.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class A
- 32 kWh
- Diagonal Size
- 24"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.276 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72% NTSC
- Response Time
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP, Advanced Motion Accelerator (AMA) technology, Dynamic Power Saving (DPS), Low Blue Light Mode, Flicker Free technology, Colour Temperature Selection, 72% NTSC colour gamut
- Black
- 57.9 cm x 6.3 cm x 35 cm - without stand
- 5.3 kg
Audio
- Speakers - stereo
- Output Power / Channel
- 2 Watt
- VGA , HDMI , DisplayPort , Audio line-in/out , Headphones
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 90
- Height Adjustment
- 110 mm
- Cables Included
- 1 x DisplayPort cable - 1.5 m , 1 x VGA cable - 1.5 m
- MTBF
- 60,000 hour(s)
- Security Slot Type
- Kensington security slot
- Input Voltage
- AC 120/230 V
- 22 W
- Power Consumption (Typical)
- 33 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Dimensions & Weight Details
- Without stand - width: 57.9 cm - depth: 6.3 cm - height: 35 cm - weight: 5.3 kg , With stand - width: 57.9 cm - depth: 21.3 cm - height: 50.2 cm , With stand - width: 57.9 cm - depth: 21.3 cm - height: 39.2 cm
Sustainability Information
- ENERGY STAR Certified
