Enjoy the spacious view while reviewing work documents or catching up on the latest show online! Featuring a 21.5"W 16:9 LCD display, 40000:1 dynamic contrast ratio, DVI connector and 5ms response time, the BenQ G2255 is built to deliver the best picture quality for work or play!
A visual performance for the best enjoyment in life
An enjoyable addition to your everyday home or work life, the G2255 gives you crisp and accurate viewing at all times. -
40000:1 dynamic contrast ratio offers you the finest details
The G2255 comes with a dynamic contrast ratio of 40000:1 to add color depth and definition to darkened and complex motion pictures, so that everything you see, from the brightest white to the darkest black, is perfectly rendered to deliver the clearest, smoothest picture performance during movies and video games. -
Full HD 1080p 16:9 visual perfection
The BenQ G2255 supports the Full HD 1080p with 16:9 aspect ratio - allowing the subtlest details to stand out with richer, more realistic colors, making your viewing experience even more absorbing. -
Superior response time
Enjoy high dynamic videos without ghosting or other artifacts with 5ms response time. -
Senseye 3 visual solution to your everyday viewing needs
Experience the truest colors of the world with the BenQ Senseye Human Vision technology. With the help of its six proprietary calibration techniques, Senseye 3 delivers only the best viewing quality in each of its six pre-set viewing modes - standard, movie, game, photo, sRGB, and eco - with the eco mode especially designed to save power and money. -
Win 7 compatible
The G2255 has passed Windows 7 certification and are fully compatible with Windows 7 color systems. Plug in the G2255 to your computer, and Windows 7 will recognize it instantly, making setup and connection effortless. -
ecoFACTS label
ecoFACTS can tell you how eco-friendly BenQ products are! ecoFACTS declares BenQ's greatest efforts on the replacement of hazardous substances, material selection, packaging design, energy-saving design and other aspects of the products. -
Energy Star qualified
The G2255 complies with the requirement of Energy Star program for computer monitors, version 5.1. Now you can enjoy saving energy and money as well as keeping the Earth looking great!
- BenQ G2255 - LCD monitor - Full HD (1080p) - 21.5"
- LCD monitor - 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- 600:1 / 40000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Tilt
- Glossy black
- 52.4 cm x 17.3 cm x 39.9 cm
- 3.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- TUV, RoHS
- 2-year warranty
- Display Type
- LCD monitor / TFT active matrix
- Diagonal Size
- 21.5"
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 200 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 76 Hz
- Horizontal Refresh Rate
- 24 - 83 kHz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 90
- Vertical Viewing Angle
- 65
- Controls & Adjustments
- Colour temperature
- sRGB colour management, HDCP, Senseye Human Vision Technology, Senseye 3 Technology
- Glossy black
- 3.7 kg
- VGA , DVI-D
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- VESA Mounting Interface
- 100 x 100 mm
- TUV, RoHS
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Power Consumption (Typical)
- 30 Watt
- Power Consumption Stand by / Sleep
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 2 years - pick-up and return
