Belkin Wireless N+ BT/ADSL Modem Router
Customer rating: 4.0* (Write a review)
Quicklinx: 5C8JWS00 Mfr#: F5D8635UK4A
  • IEEE 802.11n (draft 2.0)
Belkin's N+ Wireless Modem Router is based on the draft 802.11n 2.0 technology which provides a wireless network that has the range to easily cover any-size home or office. The N+ Modem Router has the bandwidth and speed for handling media intensive applications that take up large amounts of your bandwidth.
A USB Storage port on the back of the router enables you to connect USB storage devices such as an external hard drive or thumb drive to the network. Now you can centrally store and share media content and files from the USB hard drive to every computer on the network.
The N+ Wireless Modem Router is the central connection point of your wireless network. You can add up to 16 computers to your Wireless Network with additional desktop and notebook adapters. Position your Belkin Modem Router in between your Broadband ADSL line and your computer to start sharing your broadband Internet access.
For better wireless performance, use the Belkin N+ Wireless Modem Router with an N+ Wireless USB Adapter (F5D8055) connecting your client computers. (Sold separately)
Belkin F5D8635-4 - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
DHCP support, NAT support, SPI, MAC address filtering, VPN passthrough, MIMO technology, WPS
Environmental Standards
ENERGY STAR Qualified
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Communications
DSL modem
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x DSL - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Antenna Qty
2
External power adapter
ENERGY STAR Certified
1 x network cable , 1 x phone cable
United Kingdom
Software Included
Drivers & Utilities
Limited warranty - lifetime
Customer reviews
Write a review for the Belkin Wireless N+ BT/ADSL Modem Router here!
Great
Reviewed by Anonymous Review Posted 10/03/2009
Fast delivery as usual.
Attached to BT line, ran setup, no need to do any manual setup, up and running with wireless connection in about 10 to 15 mins, but best of all the broadband speed went from an average of 0.5 meg to an average of 3 meg, and I can use the laptop anywhere in the house.
So I am very pleased with it.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent speed
Reviewed by Faisal. Review Posted 26/12/2008
This is a very good modem/router. I had it up and running using Sky Broadband in 15 mins. From previous reviewer, I had a problem using it with XBOX Live, quick look on Xbox.com/support, and I was connected. Very good range and speed. Highly recommended
  • Overall 5*
  • Ease of use 5*
Hit... and Miss!
Reviewed by Paul. Review Posted 05/03/2009
Chose this because -Better connectivity (bandwidth/reliability) -USB connection for external hard drive. -Eco-mode: Disable wireless during the night. Only having a Netgear834 to compare against, setup was clunky & could be clearer. By the 3 or 4th time I was a Pro! Lot of intermittent faults: Wireless drop-outs, unexplained 'limited connectivity only' resulting in rebooting router regularly. Connectivity worse than Netgear 834G, Storage Manager software is poor (unintuitive, doesn't do what says on the tin). Had to manually map a drive to the external hard drive (not difficult, but not met expectations. Eco-mode for wireless did not work. Period. So sent it back, asked Dabs to replace (they were great). Everything on 2nd one works (though wireless eco-mode still needs an occasional reboot to wake up, may give up on this). Still had to Map Drive to external hard drive, but no great hardship. So - it's good, but you have to be patient, persistent and like a challenge!
  • Overall 4*
  • Ease of use 4*
Read all 7 customer reviews
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
