Store and Charge Go is the ideal solution to store and charge multiple devices safely and conveniently. A base unit stores a few devices and can be attached securely to a desktop or wall to save space. Removable five-compartment trays add portability for easy transportation. Able to charge a few devices at the same time, while housing all charging cables neatly within the base unit, Store and Charge Go offers a universal storage solution for laptops, tablets and more. Portable trays allow for customization.
Portability important
Store and Charge Go features removable trays for added portability. Designed to fit snugly within the base unit, these five-device trays feature easy-to-carry ergonomic handles. This makes it easy to bring devices from the place of charging to around the classroom for time-saving distribution among students. -
Multi-device compatible
Able to house a few mobile devices, Store and Charge Go accommodates laptops and tablets with or without cases. This means simultaneous charging for different devices, from different brands, using different charging connectors - with the added bonus, that added devices will also slot in seamlessly. -
Cost-efficient
With so many features built-in, Store and Charge Go offers a high-value solution, that delivers a low cost per device - essential for today's cost-sensitive classrooms. The simple, effective, and scalable design keeps installation and setup costs minimal and requires little to no maintenance on a day-to-day basis. -
AC configuration
The AC configuration combines a metal-case, surge-protected power source with wide-spaced outlets and an on/off switch.
- Belkin Store and Charge Go with portable trays - charging stand
- Charging stand - external
- Localisation
- United Kingdom
- Included Accessories
- Power supply
- 60.5 cm x 32.83 cm x 38.62 cm
- Localisation
- United Kingdom
- Power supply
- Equipment Protection Value
- 10000 British Pounds
- Surge protection, removable bins, cable management
- 60.5 cm
- 32.83 cm
- 38.62 cm
