Belkin OmniView SMB 1x16 KVM-over-IP Switch
Quicklinx: 4D09WS00 Mfr#: F1DP116GEA
The OmniView IP KVM Switch enables network administrators to monitor and control their servers from anywhere, at any time. This round-the-clock access lets you troubleshoot servers faster and more efficiently, dramatically reducing server downtime and service costs. Designed to grow along with your server network, the Switch expands to support up to 256 servers via daisy-chaining. The Switch features built-in CAT5 technology to provide simplified deployment and reduced cable clutter.
One Server Interface Module is required per server connected to the OmniView IP KVM Switch. Server Interface Modules are available for PS/2, USB, and Legacy Sun servers.
Belkin Omniview SMB 1x16 KVM-over-IP Switch - KVM switch - 16 ports
KVM switch - 16 ports - CAT5 - stackable
Enclosure Type
1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Users Qty
1 local user, 1 IP user
On-Screen Display, firmware upgradable
43.8 cm x 19 cm x 4.5 cm
2.3 kg
Novell NetWare 5.x, Microsoft DOS 5.x or later, Microsoft Windows Server 2003, Red Hat Linux 8.x, SunSoft Solaris 8 or later, Microsoft Windows NT / 2000 / XP
KVM switch - 16 ports - stackable
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
16 x KVM port(s)
KVM Local Users Qty
1 local user
KVM IP Users Qty
1 IP user
Server Connection Via Twisted Pair
CAT5
Keyboard / Mouse Interface
PS/2
Encryption Algorithm
SSL
Max Resolution
1600 x 1200 @ 75 Hz
On-Screen Display, firmware upgradable, IP-based user connection, server connection via twisted pair
Status Indicators
Port status
16 x KVM RJ-45 , 1 x network stack device , 1 x RJ-45 management , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2)
External power adapter
43.8 cm
19 cm
4.5 cm
2.3 kg
0 - 80%
