Your basket is empty
Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch
Quicklinx: 4PJBWS00 Mfr#: F1DA108ZEA
Type: KVM switch
Connectivity: KVM
Ports: 8
Hurry, only 2 left in stock!
£194.44 ex VAT
£233.32 inc VAT
The OmniView PRO3 USB and PS/2 KVM Switch provides easy and dependable server control with extraordinary performance. The Switch enables network administrators to monitor and control up to four, eight, or 16 USB- and PS/2-platform servers from a single console. The PRO Series KVM Switches are the industry's most popular for small to medium server rooms, branch locations, and test and development labs. Designed to grow along with your server network, the Switch can be daisy-chained together using dedicated daisy-chain ports with other OmniView PRO Series or SMB KVM Switches to support up to 256 servers.
Belkin PRO3 KVM Cables are required to connect your servers and computers.
Belkin OmniView PRO3 USB & PS/2 8-Port KVM Switch - KVM switch - 8 ports
KVM switch - 8 ports - stackable
Subtype
KVM
Ports
8 x KVM port(s)
On-Screen Display, firmware upgradable
43.8 cm x 19 cm x 4.5 cm
4.2 kg
SunSoft Solaris 8, Novell NetWare 5.x, Microsoft DOS 5.x or later, Apple MacOS X, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Vista
3 years warranty
Bundled Services
3 years warranty
Belkin OmniView Dual-Rail LCD Console
Enclosure Type
Desktop
Subtype
KVM
Ports
8 x KVM port(s)
Keyboard / Mouse Interface
PS/2
Max Resolution
1920 x 1440 @ 75 Hz
Status Indicators
Port status
8 x KVM - 50 pin Centronics , 2 x network stack device - DB-25 , 1 x RJ-11 - management , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x keyboard (USB) - Type A , 1 x mouse (USB) - Type A , 1 x VGA - HD-15
External power adapter
1 x serial cable
Rack Mounting Kit
Included
43.8 cm
19 cm
4.5 cm
4.2 kg
Limited warranty - 3 years
0 - 80%
4PJB Belkin OmniView Dual-Port PS/2 KVM Cable 1.8m In Stock £16.48
4PJB Belkin Omniview Ent Series Dual-Port USB KVM Cable 1.8m In Stock £16.48
Type: KVM switch
Connectivity: KVM
Ports: 8
Brand: Belkin
Price Range Ex VAT: 150 - 300
